    How to enter USB Mode on CORE2
    3 Posts 3 Posters 4.2k Views
      AEisele55
      How can i get to usb mode on core2 without using m5burner every time?
      I saw that on the original core, you could press a button (a physical one that is now a touch surface) to select start mode.
      Is this still possible on the core2?
      Aaron
      M5Core2, M5Atom Matrix + dLight Unit, M5stickCplus
        When the core2 boots up it should give you the option to enter menu by pressing the touch zone.
          Hello @AEisele55
          on M5Stack you can select Setup - Switch Mode - USB Mode and reboot.
          However on M5Core2 this option is missing. Setup doesn't have a Switch Mode entry.(Tested with UIFlow firmware v1.10.6)
