    How do you Uninstall TimerCam image on the ESP32 TimerCam?
    4 Posts 3 Posters 4.0k Views
      drobertson123
      I was testing my new ESP32 TimerCam and burned the TimerCam package. It seems to be working but the snapshot cycle goes so fast that I can't connect to the board to reset it.
      I just want to erase the Timer Cam and start over. How can I accomplish this?
        Use M5Burner to wipe the current firmware and replace with factory firmware
          drobertson123 @ajb2k3
          @ajb2k3 The program runs and then shuts down very quickly. The M5Burner doesn't have time to connect.
            Hello @drobertson123
            not sure it helps, but have you tried to press and hold the power key while using M5Burner? I think that should keep it from shutting down.
