    M5Stack Paper I2C Doesn't work
    15 Posts 5 Posters 21.3k Views 1 Watching
    • I Offline
      ispybadguys
      Thanks. I'll try that. When I call M5.begin(); I get the following behavior.
      M5EPD initializing...OK
      continues forever.
      • I Offline
        ispybadguys
        If I comment out the internal I2C section so I only have the PORT-A scan I get the following:
        Scanning external I2C (PortA)
        ..............................................................................................................................Done Scanning PortA I2C
        It takes about one second for each address scanned. This is probably the default timeout.
        Kurt
          ajb2k3 @ispybadguys
          @ispybadguys What external devices have you tried connecting?
            Hello @ispybadguys
            are you saying that simply calling M5.begin() in setup(), e.g.
            #include <M5EPD.h>
            produces M5EPD initializing...OK over and over again?
              Hello @ispybadguys
              please find the I2C internal and all port scanner (which works for me) here.
              • I Offline
                ispybadguys
                Yes. I tested the very code you have here with just to include and M5.begin() and I get M5EPD initializing... followed by a 4 second pause and then the OK
                • I Offline
                  ispybadguys
                  Thanks for the code . For scanning the I2C. The code produces the following output:
                  I2C Scan - internal
                  .M5EPD initializing...OK
                  I2C Scan - internal
                  I2C Scan - internal
                    Hello @ispybadguys
                    that is very weird - I am stumped.
                    Have you tried to only scan the ports by commenting these two lines:
                    //  Serial.println("I2C Scan - internal");
                    //  scanI2C(i2cBus_Internal.wire, i2cBus_Internal.sda, i2cBus_Internal.scl);
                    BTW: I also get a 4 seconds delay before OK is printed out - so that should be fine.
                    • I Offline
                      ispybadguys
                      Yes. I just tried that. I get the same behavior. I moved the script to a new Windows computer and installed the IDE there. I get
                      13:10:21.290 -> I2C Scan - Port A
                      13:10:21.290 -> .M5EPD initializing...OK
                      13:10:25.790 -> I2C Scan - Port A
                      I can actually scan the internal ports correctly if I don't call M5.begin(); and I just do a Serial.begin() and the wire commands.
                      BTW the boards.txt has an error in it for the M5-Paper and you cannot upload code from the Arduino IDE. I fixed that and I can upload ok now.
                      Kurt
                        Hello @ispybadguys
                        the debug output suggests that as soon as the I2C port scan starts (first dot) your M5Paper seems to reboot.
                        • Have you tried a different / shorter USB cable? Maybe the issue is power related?
                        • Does the touch example (requires internal I2C) work?
                        • I Offline
                          ispybadguys
                          Yes. That looks to be the case that it crashed after one or two Wire1 commands. Usually one period is printed but sometimes two. Also the internal I2C does not work is I call M5.begin but it does if I just call Wire.begin.
                            Koiru
                            I'm having exactly the same issue. Have you figured out what causes it?
                              Morne
                              @Koiru I have not found a solution but I have found a workaround.
                              The culprit creating the constant reboots are the touchscreen, if I call the begin function without enabling the touchscreen I can get the unit to work instead of doing constant reboots.
                              To initialize the unit without touchscreen, use the following arguments:
                              M5.begin(false, true, true, true, true);
