    (Core2 AWS) LCD does not light up
    5 Posts 5 Posters 5.4k Views
      hiranobu
      Hello, I am a Beginner.
      The LCD on my Core2AWS has stopped lighting up.
      The power seems to be on, writing is normal, and when I restore the firmware to its initial state with M5Burner, the LCD lights up again, so it does not seem to be a hardware failure.
      After writing the sketch using ArduinoIDE, the LCD will not light up.
      I would appreciate any good advice you can give me.
      I posted this using an automatic translation service. Sorry if it was funny English.
        Hello @hiranobu
        have you tried a simple sketch like this one? Does that work?
          Have you made sure that you are restoring Core2 firmware and not core firmware.
          • V Offline
            villagertechnology
            @hiranobu pou said in (Core2 AWS) LCD does not light up:
            You should try bringing it to the store. They can better assist you
            • robskiR Offline
              robski @hiranobu
              @hiranobu said in (Core2 AWS) LCD does not light up:
              does it work if you use UIflow?
