    Canvas don't work on M5Stack Core 2
    Micropython
    3.4k
    • pavelprostoP
      pavelprosto
      I'm try run simple code:
      import lvgl as lv
      def LV_IMG_BUF_SIZE_ALPHA_1BIT(w, h):
          return int(((w / 8) + 1) * h)
      def LV_IMG_BUF_SIZE_INDEXED_1BIT(w, h):
          return LV_IMG_BUF_SIZE_ALPHA_1BIT(w, h) + 4 * 2
      def LV_CANVAS_BUF_SIZE_INDEXED_1BIT(w, h):
          return LV_IMG_BUF_SIZE_INDEXED_1BIT(w, h)
      CANVAS_WIDTH  = 50
      CANVAS_HEIGHT = 50
      # Create a buffer for the canvas
      cbuf= bytearray(LV_CANVAS_BUF_SIZE_INDEXED_1BIT(CANVAS_WIDTH, CANVAS_HEIGHT))
      # Create a canvas and initialize its the palette
      canvas = lv.canvas(lv.scr_act(), None)
      canvas.set_buffer(cbuf, CANVAS_WIDTH, CANVAS_HEIGHT, lv.img.CF.INDEXED_1BIT)
      canvas.set_palette(0, lv.color_hex(0x00ff00))
      canvas.set_palette(1, lv.color_hex(0xff0000))
      # Create colors with the indices of the palette
      c0 = lv.color_t()
      c1 = lv.color_t()
      c0.full = 0
      c1.full = 1
      # Transparent background
      canvas.fill_bg(c1, lv.OPA.TRANSP)
      # Create hole on the canvas
      for y in range(10,30):
          for x in range(5,20):
              canvas.set_px(x, y, c0)
      An error occurs when running the code.
        File "<stdin>", line 19, in <module>
      AttributeError: 'NoneType' object has no attribute '__dereference__'
      But everything works in the lvgl simulator.
        ajb2k3 @pavelprosto
        @pavelprosto Its very hard to diagnose issue in MP as sometimes the error message does not actually point to the issue!
        The error could be
        or
        • pavelprostoP
          pavelprosto
          code:
          import lvgl as lv
          error:
            File "<stdin>", line 2, in <module>
