    Backticks... (Request to admins)
    Lessons and Guides
    6
    14.0k
    • RopR
      Rop
      Hello people running this board...
      Can we please have a sticky post pointing out that people should put code between two lines with three backticks (These things: -> ` <-) on them so that when they post their code it ends up looking like this:
      #include <M5ez.h>
          ez.begin();
          ez.msgBox("M5ez minimal program", "Hello World !", "Settings");
          ez.settings.menu();
      and not like this:
      #include <M5ez.h>
      ez.begin();
      ez.settings.menu();
      • C
        CrazyHorse80
        It should be good to explain how to use other tags, too (if any).
        Thank you in advance!
          Or even what tags are available.
          • loborisL
            loboris
            Formating guide
            Link also available when you click on question mark in edit window.
            The help apears in chinese:
            Markdown
            该论坛使用 Markdown 语法。点此查看 语法说明。
            Translated:
            Markdown
            This forum uses the Markdown syntax. Click here for the syntax description.
            • C
              CrazyHorse80
              Thank you!
                Thank you.
