    COM.X 868 doesn't response in Com Monitor
    m5go
    1 Posts 1 Posters 3.6k Views
      FLOSCH
      I'm working with the M5Core v1.9.8, i also have the COM.LoRaWan Module(868Mhz v2.0 ) installed on my M5Go.
      The Purpose is to send Data from M5Go to the TTN. Therefore i used the manual from M5Stack COM.LoRaWAN Using UIFlow
      in the Com Monitor in M5Burner i only get the text i sent in the command bar below as result.
      The PIN configuration in the UART Block is default (17/16). The programm with the UART forwarding is running.
      Does anyone have some inputs for that issue?
      Thank you in advance
      Flo
