    M5 Station Battery version doesn't last this long
    Modules
    2.5k
    • F
      FLOSCH
      Hi all,
      I'm using the M5 Station Battery Version. Attached i have the Co2/temp/Hum sensor.
      The case is to connect to a WIFI, make a connection to MQTT Broker then read the actual values from the sensor. After this i put the device in deep sleep mode with following command "M5.Axp.DeepSleep(SLEEP_SEC(60));".
      This tasks take about 5 seconds then the Station goes to deep sleep.
      This all works fine when is plugged in to power supply but when i run the Station without supply the battery doesn't even last over night. Further i can see in the MQTT Broker that not always the 60 seconds take place.
      So i published the batterylevel too, that i can see what going on but there is always the value 100 (fully charged).
      The batteries are the original ones and the Station was plugged during working hours through USB Port.
      Does everyone know if I'm doing things wrong?
      Here is the code.
      #include <TinyGPSPlus.h>
      #include <ETH.h>
      #include <dummy.h>
      #include <EEPROM.h>
      #include <M5Station.h>
      #include <I2C_AXP192.h>
      #include <WiFi.h>
      #include <PubSubClient.h>
      #include <SensirionI2CScd4x.h>
      // Hardware definitions
      SensirionI2CScd4x Co2Sensor;
      // TinyGPSPlus gps;
      // HardwareSerial GPSRAW(2);
      // Network details
      const char *ssid = "ssid";
      const char *wifi_password = "password";
      // MQTT broker
      const char *mqtt_server = "IP Address";
      const char *mqtt_topic_temp = "M5/Temperature";
      const char *mqtt_topic_co2 = "M5/co2";
      const char *mqtt_topic_humidity = "M5/Humidity";
      const char *mqtt_topic_batterylevel = "M5/Batterylevel";
      const char *mqtt_topic_batteryPower = "M5/BatteryPower";
      const char *mqtt_topic_batterycurrent = "M5/Batterycurrent";
      const char *mqtt_topic_batteryvoltage = "M5/Batteryvoltage";
      const char *mqtt_username = "username";
      const char *mqtt_password = "password";
      const char *mqtt_client_id = "KRL";
      // Variables
      uint8_t batterylevel = M5.Axp.GetBatteryLevel();
      float batterypower = M5.Axp.GetBatPower();
      float batteryvoltage = M5.Axp.GetBatVoltage();
      float batterycurrent = M5.Axp.GetBatCurrent();
      WiFiClient wifi_client;
      PubSubClient client(mqtt_server, 1883, wifi_client);
      void setup()
      M5.begin(115200);
      M5.Axp.begin();
      delay(1000);
      M5.Lcd.setTextFont(4);
      M5.Lcd.drawString(String(batterylevel), 110, 0);
      M5.Lcd.drawString(String(batterypower), 160, 20);
      M5.Lcd.drawString(String(batteryvoltage), 160, 40);
      M5.Lcd.drawString(String(batterycurrent), 160, 60);
      uint16_t error;
      char errorMessage[256];
      Co2Sensor.begin(Wire);
      // stop potentially previously started measurement
      error = Co2Sensor.stopPeriodicMeasurement();
      if (error)
          Serial.print("Error trying to execute stopPeriodicMeasurement(): ");
          errorToString(error, errorMessage, 256);
          Serial.println(errorMessage);
      // Start Measurement
      error = Co2Sensor.startPeriodicMeasurement();
      if (error)
          Serial.print("Error trying to execute startPeriodicMeasurement(): ");
      Serial.println("Waiting for first measurement... (5 sec)");
      connect_to_wifi();
      connect_to_mqtt();
      delay(3000);
      get_data_and_publish();
      disconnect_wifi_MQTT();
      sleepy();
      void loop()
      void sleepy()
      Serial.println("Going to sleep...");
      delay(1000);
      void disconnect_wifi_MQTT()
      WiFi.disconnect();
      delay(1000);
      client.disconnect();
      Serial.println("WIFI and MQTT disconnected");
      void get_data_and_publish()
      uint16_t error;
      delay(100);
      // Read Measurement
      uint16_t co2_measured = 0;
      float temperature_measured = 0.0f;
      float humidity_measured = 0.0f;
      bool isDataReady = false;
      Serial.println("Start measuring....");
      error = Co2Sensor.getDataReadyFlag(isDataReady);
      if (error)
      M5.Lcd.print("Error trying to execute readMeasurement(): ");
      return;
      if (!isDataReady)
      Serial.println("Data isnt ready!");
      return;
      error = Co2Sensor.readMeasurement(co2_measured, temperature_measured, humidity_measured);
      if (error)
      else if (co2_measured == 0)
      Serial.println("Invalid sample detected, skipping.");
      else
      Serial.println("Show Measurement");
      M5.Lcd.setCursor(0, 35);
      M5.Lcd.printf("Co2:%d\n", co2_measured);
      M5.Lcd.printf("Temp.:%f\n", temperature_measured);
      M5.Lcd.printf("Humidity:%f\n", humidity_measured);
      String valuesToSend_temp = String(temperature_measured);
      String valuesToSend_co2 = String(co2_measured);
      String valuesToSend_humidity = String(humidity_measured);
      String valuesToSend_batterylevel = String(batterylevel);
      String valuesToSend_batteryPower = String(batterypower);
      String valuesToSend_batteryvoltage = String(batteryvoltage);
      String valuesToSend_batterycurrent = String(batterycurrent);
      client.publish(mqtt_topic_temp, valuesToSend_temp.c_str());
      client.publish(mqtt_topic_co2, valuesToSend_co2.c_str());
      client.publish(mqtt_topic_humidity, valuesToSend_humidity.c_str());
      client.publish(mqtt_topic_batterylevel, valuesToSend_batterylevel.c_str());
      client.publish(mqtt_topic_batteryPower, valuesToSend_batteryPower.c_str());
      client.publish(mqtt_topic_batteryvoltage, valuesToSend_batteryvoltage.c_str());
      client.publish(mqtt_topic_batterycurrent, valuesToSend_batterycurrent.c_str());
      Serial.println("Messages published...");
      client.loop();
      delay(2000);
      void connect_to_wifi()
      WiFi.persistent(false);
      WiFi.disconnect();
      WiFi.mode(WIFI_STA);
      // Connect to the network
      WiFi.begin(ssid, wifi_password);
      Serial.println("Connecting to WiFi");
      int retry_count = 0;
      while (WiFi.status() != WL_CONNECTED && retry_count < 15)
      delay(1000);
      retry_count++;
      Serial.print(".");
      if (WiFi.status() != WL_CONNECTED)
      ESP.restart();
      Serial.println("");
      Serial.println(WiFi.localIP());
      void connect_to_mqtt()
      while (!client.connected() && retry_count < 15)
      // Connect to MQTT broker
      if (client.connect(mqtt_client_id, mqtt_username, mqtt_password))
      Serial.println("Connected to MQTT Broker!");
      else
      Serial.println("Connection to MQTT Broker failed...");
      Serial.println(client.state());
      retry_count++;
      delay(1000);
      if (!client.connected())
      ESP.restart();
        Hello @FLOSCH
        the reason battery level, power, voltage and current are incorrect is that the calls to GetBatteryLevel(), GetBatPower(), GetBatVoltage() and GetBatCurrent() are happening before I2C is initialized and therefore return invalid values. You'll need to do this calls inside setup() and after M5.begin().
