    M5Station lack of support .. or am I looking in the wrong place !
    Modules
    4.9k
    • A
      AshimotoK0
      Just started using M5Stack last Thursday but pretty impressed I now have a monitoring setup recording 6 analogue add-on channels and successfully reading the data in Qubitro. But is the M5StationBAT a new product as I can find very little on it on the internet specific to that unit and a there seems a scant lack of documentation. For instance having achieved what I basically needed for my project, I am now completely stuck with simple basic tasks ... for example how do you drive the 7 LED's on this unit?
        ajb2k3 @AshimotoK0
        @ashimotok0
        What program language are you using?
        Alas I can only use mine from command line as I lost my display
          Hello @AshimotoK0
          have a look at the factory test code or the example I've created.
          General information about M5Station can be found here.
          • A
            AshimotoK0 @ajb2k3
            @ajb2k3 Thanks I am using UIFlow
              Hello @AshimotoK0
              ok, in that case, in UIFlow, have you tried to use the RGB blocks under Hardware to control the 7 LEDs?
              • A
                AshimotoK0 @felmue
                @felmue ..Thanks for that a colleague sussed that out just before I read your reply but many thanks as you were dead right... as all up and running now. For anyone reading this reply the illumination of the centre main on/off button is LED #4 I didn't realize that the LED's are multi colour until I studied the circuit diagram/schematic ...cool !
