    TouchButton awol?
    Core 2
    2.5k
    • B
      brianteeman
      Trying to write my first arduino code using Touch.
      The API docs give several examples but none of them work. Using the code in the very first example for TouchEventStructures https://docs.m5stack.com/en/api/core2/touch
      Errors include
      • 5:1: error: 'TouchButton' does not name a type; did you mean 'Button'?
        TouchButton rt = TouchButton(160, 0, 160, 120, "right-top");
      • 9:19: error: variable or field 'eventDisplay' declared void
        void eventDisplay(TouchEvent& e) {
      • 9:19: error: 'TouchEvent' was not declared in this scope
      Using
      • Arduino IDE 2.0.3
      • M5Core2 0.1.5
      • Windows 11
        Hello @brianteeman
        the documentation is probably not fully up-to-date.
        Maybe checkout the description here.
        Also have a look at this example.
          Have you got all the libraries imported?
          5.1 and 9.19 mean that they haven't been defined or the libraries not imported or that you are compiling for the wrong device.
