    M5StickC-Plus Screen "Flash" on Startup
    1 Posts 1 Posters 2.2k Views 1 Watching
    • W Offline
      wsanders
      If you run the following trivial program, you will notice that the screen "flashes" with uninitialized data at startup.
      #include <M5StickCPlus.h>
      // DANGER WILL ROBINSON: This sketch turns the device off. To upload,
      // turn the device on as soon as you see "Connecting..." in the IDE.
      // Otherwise the device isn't on when you try to upload to it!
      // This does not minimize the beightness of the "flash"
      // M5.Axp.ScreenBreath(7);
      M5.Lcd.fillScreen(BLACK);
      M5.Lcd.setTextSize(3);
      M5.Lcd.println("BYE");
      delay(5000);
      M5.Axp.PowerOff();
      Is there a way to avoid this "flash"? This is probably a bug in M5.begin(), one would want to initialize the screen memory before turning the LCD on.
