    HSPI on M5Stack Tough
    3 Posts 2 Posters 2.8k Views
      hgi867
      Please tell me which GPIO pins can be used for HSPI on M5Stack Tough.
      I assigned the pins as follows but cannot communicate.
      SPIClass hspi(HSPI);
      // CLK, MISO, MOSI, CS
      hspi.begin(19, 27, 32, 33);
      pinMode(csPin, OUTPUT);
      digitalWrite(csPin, HIGH);
      Initially, I used CS pin 13 to connect an external sensor with VSPI. However, after compiling, I could get values from the sensor and write them to an SD card, but when I turned the power back on, only 0.00 values were obtained. I don't know the cause.
      So, I'm trying to switch from VSPI to HSPI, but it's not working.
      Thank you.
        Hello @hgi867
        you cannot use GPIO19 and GPIO27 - they are not connected directly to the RS485 port. See second schematic here.
        I had success using HSPI with the following GPIOs:
        SCK - GPIO33
        MISO - GPIO36
        MOSI - GPIO32
        CS - GPIO26
          hgi867
          Thanks for the advice.
          it works for me too.
