    Initiating connection to AWS
    7 Posts 2 Posters 8.3k Views
    • B Offline
      bmtd111
      Dear People
      I am currently working on a System that needs to connect to AWS. Sadly i get the following Error messages when I Execute my code: 0_1679405029035_Support.PNG
      I am using an ATOM Lite and UIFlow 1.11.3
      I hope you guys can help me
      With kind regards,
      TD
      • B Offline
        bmtd111
        Line 51 in my code is just aws.start() and it seems to call functions in the libraries. Maybe there is a bug in IoTCloud/AWS.py?
          Please post all the python code.
          errors don't always apply to a specific line and also don't count empty lines.
          IIRC (and there's a possibility I don't as it was last year) have you set up the digital twin and permissions on AWS for the code to connect?
          • B Offline
            bmtd111
            Thank you for your reply!
            Here is my Pythoncode:
            from m5stack import *
            from m5ui import *
            from uiflow import *
            import machine
            import wifiCfg
            from IoTcloud.AWS import AWS
            import ntptime
            import json
            PingCounter = None
            ThingsName = None
            currentDoorState = None
            lastDoorState = None
            from numbers import Number
            @timerSch.event('AWSTimer')
            def tAWSTimer():
            global PingCounter, ThingsName, currentDoorState, lastDoorState, pin1
            if wifiCfg.wlan_sta.isconnected():
            PingCounter = (PingCounter if isinstance(PingCounter, Number) else 0) + 1
            aws.publish(str('DoorState/ping'),str((json.dumps(({'time':(ntp.formatDatetime('-', ':')),'ping':PingCounter,'reconnect':False})))))
            else:
            wifiCfg.doConnect('BesserMITTAG-IOT', "Zsip-uwYpDe'")
            aws.publish(str('DoorState/ping'),str((json.dumps(({'ping':PingCounter,'time':(ntp.formatDatetime('-', ':')),'reconnect':True})))))
            pass
            @timerSch.event('restartTimer')
            def trestartTimer():
            machine.reset()
            pass
            import gc
            wifiCfg.doConnect('blank', "blank'")
            ntp = ntptime.client(host='de.pool.ntp.org', timezone=1)
            timerSch.run('restartTimer', 10800000, 0x00)
            PingCounter = 0
            ThingsName = 'D30002'
            aws = AWS(things_name=ThingsName, host='hostName', port=8883, keepalive=1000, cert_file_path="/flash/res/certificate.pem.crt", private_key_path="/flash/res/private.pem.key")
            aws.start()
            gc.collect()
            aws.publish(str('DoorState/connect'),str((json.dumps(({'connect':'request'})))))
            timerSch.run('AWSTimer', 900000, 0x00)
            pin1 = machine.Pin(26, mode=machine.Pin.IN, pull=machine.Pin.PULL_UP)
            currentDoorState = pin1.value()
            while True:
            lastDoorState = currentDoorState
            if lastDoorState == 1 and currentDoorState == 0:
            rgb.setColorAll(0x33cc00)
            aws.publish(str('DoorState/test'),str((json.dumps(({'open':(ntp.formatDatetime('-', ':')),'Message':'15','TopicArn':'arn:aws:sns:eu-central-1:684143602652:L-from-device','MessageAttributes':({'DataType':'String','StringValue':'door-opened'}),'DeviceID':({'DataType':'String','StringValue':'A1005'})})))))
            elif lastDoorState == 0 and currentDoorState == 1:
            rgb.setColorAll(0xff0000)
            aws.publish(str('DoorState/test'),str((json.dumps(({'close':(ntp.formatDatetime('-', ':')),'Message':'16','TopicArn':'arn:aws:sns:eu-central-1:684143602652:L-from-device','MessageAttributes':({'DataType':'String','StringValue':'door-closed'}),'DeviceID':({'DataType':'String','StringValue':'A1005'})})))))
            wait_ms(2)
            I have set everything up in AWS, the connection was already established and worked fine.
            Do you mean a device shadow with digital twin? I dont see how that could resolve the issue.
            With kind regards,
            TD
              If I read correctly it means that the MQTT connection to AWS wasn't acknowledge which meant permission was refused.
              Have you restarted the ATOM or has AWS changed anything?
              Sorry, I haven't used AWS in a while
              • B Offline
                bmtd111
                I tried restarting it, that didnt change anything.
                @ajb2k3 said in Initiating connection to AWS:
                Were did you read that the connection wasnt established?
                  Combination of error 09 (authentication acknowledgment error) and OS error shown in the command terminal
