    UHF RFID unit problems interfacing with arduino mega using code example from github
    Units
    uhf rfid arduino
    3.8k
    • K
      kasperhvid
      I have purchased your reader and i am trying to port the library from this url:
      https://github.com/m5stack/M5Unit-UHF-RFID
      To work on an arduino mega. So far i'm not having much luck. I can't even get the UHF RFID unit to print its version using getVersion in setup void much less read my tags..
      I have made the following changes to the .begin void in order to accomodate it being a mega:
      /*! @brief Initialize the Unit UHF_RFID.*/
      void Unit_UHF_RFID::begin(HardwareSerial *serial, long baud, bool debug) {
         _debug  = debug;
         _serial = serial;
         _serial->begin(baud);
      And then my setup void looks like this:
      #include "Unit_UHF_RFID.h"
      Unit_UHF_RFID uhf;
      String info = "";
       // put your setup code here, to run once:
       Serial.begin(9600);
       Serial.println("Serial begin");
       uhf.begin(&Serial2, 115200, false);
       Serial.println("Serial begin2");
       while (1) {
         info = uhf.getVersion();
         Serial.println("Version: "+info);
         if (info != "ERROR") {
           Serial.println(info);
           break;
       // max: 26dB
       uhf.setTxPower(2600);
      Hope someone can help me understand why this isn't working..
      • P
        pierrethr
        Hi @kasperhvid, any luck on that?
        I was hoping to do the same but all I get is an obscure "ERROR" response back from the getVersion() method.
