    COM.LTE Module not responding
    4 Posts 2 Posters 4.1k Views 2 Watching
      jkeyser
      Using this module with an external power supply along with the Core 2. No other modules attached at the moment.
      https://shop.m5stack.com/products/com-lte-modulesim7600g
      Only code uploaded is the example provided on uiflow, but i cant get any sort of response. The only output i get is "Text" in the top left of the screen. The program seems to hang during init and never makes it past that point. Confirmed DC power switch is on the correct setting, as well as the tx/rx dip switches.
      Flashing the easyloader results in no output to the screen, as well as a high pitched ringing from the modem
      Setting COM.X to true on m5burner gives the error 'module stable timeout'
      from m5stack import *
      from m5stack_ui import *
      from uiflow import *
      from comx.lte import LTE
      screen = M5Screen()
      screen.clean_screen()
      resp = None
      label0 = M5Label('label0', x=33, y=36, color=0x000, font=FONT_MONT_14, parent=None)
      label1 = M5Label('label1', x=37, y=63, color=0x000, font=FONT_MONT_14, parent=None)
      label2 = M5Label('label2', x=35, y=91, color=0x000, font=FONT_MONT_14, parent=None)
      label3 = M5Label('label3', x=36, y=114, color=0x000, font=FONT_MONT_14, parent=None)
      lte = LTE(tx=13, rx=5)
      label0.set_text(str(lte.check_status()))
      label1.set_text(str(lte.get_single_quality()))
      label2.set_text(str(lte.get_network_registration()))
      label3.set_text(str(lte.get_gprs_network_registration()))
      while True:
      if str((lte.get_gprs_network_registration())) == '1':
      # echo "test"
      resp = lte.http_get('http://www.m2msupport.net/m2msupport/test.php')
      if resp:
      label4.set_text(str(resp[1]))
      wait_ms(2)
      • felmueF Online
        Hello @jkeyser
        have a look at this post. It's not the same module, but I suspect the initialization process, e.g. checking for a SIM PIN, is the same.
          jkeyser @felmue
          Thanks, while looking into that I found i wasn't also unable to open any sort of connection to send AT commands. Turns out i misunderstood the dip settings for the core 2. Set to 16/17 on the modem and 14/13 on uiflow init and i have communication now.
          • felmueF Online
            Hello @jkeyser
            that is great to hear. Thank you for reporting back.
