    No LED support on new releases for the Atom Lite
    SOFTWARE
    5.3k
      mchott
      I have an running implementation using UI Flow 1.9.5 and my Atom Lite. It´s working like defined.
      After updating to the latest release 1.11.6 the built in LED of my Atom Lite stop working. The Led is still off if I only set color and brightness. Nothing happend.
        Hello @mchott
        with UIFlow 1.11.6 firmware on my M5Atom the RGB LED works just fine.
        Are you sure your M5Stack is connected to the UIFlow backend?
          mchott
          @felmue said in No LED support on new releases for the Atom Lite:
          Yes I´m sure .. I can for example control the PWM frequency. The Led is also not showing when I connect it to my Mac/PC and hold the button down. Normally the Led shows the current state of App, Internet or USB. But the Led is still dark. If I flash the version 1.9.5 on my Atom and use the same code the Led is switching the colors .. Led seems to work.
          In the past I had an different issue with an very easy control of just setting the color: https://www.instagram.com/reel/Cn9XLfWq1_l/?utm_source=ig_web_copy_link
            Hello @mchott
            hmm, not sure what is going on. Sorry.
              mchott
              Now I tried to do it extrem more on a basic level with the latest available versions of everything with Arduino
              #include <Arduino.h>
              #include <M5Atom.h>
                M5.begin(true, false, true);
                M5.dis.begin();
                M5.update();
                M5.dis.drawpix(0, 0xFF0000);
                delay(500);
              I assumed that this simply meant a permanent "RED", but it results in a random play of colours.
