    [Solved]M5Stack Fire Microphone?
    3 Posts 2 Posters 11.2k Views 1 Watching
    • B Offline
      bobolink
      Does the M5Stack Fire have a microphone?
      The advertising says it does.
      There are internet references to a MEMS BSE3729 mic on GPIO 35. But the I can’t get the Arduino mic example to work. I looked inside and I saw D1 at the enclosure mic hole which which seems to have a different purpose. I can’t find a mic on the schematic but I could have the wrong schematic or don’t know what the mic symbol looks like.
      I searched this forum and found a mic+leds+FFT example but that didn’t work either.
      Could someone provide a link to a schematic with a mic on it and give the ref designation to help me find it on the M5Stack Fire circuit board. If I can find it, I can get it to work.
      • lukasmaximusL Offline
        Hi bobolink according to the github documentation page
        https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire
        The microphone is located on pin 34
        I tested the vu meter in the Fire examples
        https://github.com/m5stack/M5Stack/tree/master/examples/Fire/M5StackFire_NeoPixelVUmeter
        and it worked fine, could you please test again using pin 34
        and see whether it works, if not it could be a faulty microphone
        • B Offline
          bobolink
          @lukasmaximus
          Thank you. Will try pin 34.
