    M5Stack library and MCP2515
    4.6k
    • B
      Bbjodel
      Hello everyone,
      I have an ESP32 WROOM 32 with a TFT ILI9341 SPI and a CAN MCP2515 SPI, but I can't operate the CAN if the command m5.begin (); is active in the code, if it is //m5.begin (); The CAN works.
      My question is how to make the TFT Ili9341 spi with the CAN MCP2515 cohabit?
      Ili9341:
      Miso (not connected) otherwise GPIO19
      Mosi ===> GPIO23
      CS =====> GPIO15
      DC =====> GPIO2
      Reset ===> GPIO4
      SCLK ===> GPIO18
      MCP2515:
      Miso ===> GPIO19
      Mosi ===> GPIO23
      CS =====> GPIO5
      SCLK ===> GPIO18
      I tried everything but without success it looks like the M5Stack library is incompatible and blocks the CAN.
      Can you help me ?
      Regards,
      Alfred from France, sorry for my english....
        Hello @Bbjodel
        in order for two SPI slaves to work their CS needs to be connected to different GPIOs. See here.
        • B
          Bbjodel
          Hello Felix Thank you for advancing, yes I know I was wrong by writing the effective position9341 CS = 15 and MCP2515 CS = 5.
          For the CS of the MCP2515 I tried from others GPIO E it returned to conflict with the M5Stack library ...
            Hello @Bbjodel
            ok, I see. Have you looked at the debut output? Are there any errors?
            • B
              Bbjodel
              I have this:
              rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
              configsip: 0, SPIWP:0xee
              mode:DIO, clock div:1
              load:0x3fff0018,len:4
              load:0x3fff001c,len:1044
              load:0x40078000,len:10124
              load:0x40080400,len:5856
              entry 0x400806a8
              Entering Configuration Mode Successful!
              Setting Baudrate Successful!
              M5Stack initializing...OK
              0,0,0.00,0,0
              0,0,0.00,0,0
              0,0,0.00,0,0
              0,0,0.00,0,0
              0,0,0.00,0,0
              0,0,0.00,0,0
              Felix can you see my code ?
              If I deactive
              //M5.begin();
              //M5.Lcd.setTextColor(WHITE);
              it works, strange.
              385,1,38.50,81,170
              385,1,38.50,81,170
              385,1,38.50,81,170
              385,1,38.50,81,170
              385,1,38.50,81,170
              385,1,38.50,81,170
                Hello @Bbjodel
                nothing stands out in the debug output unfortunately.
                Have you tried to use two separate SPI busses? Maybe the two libraries (TFT and CAN) cannot work together?
                • B
                  Bbjodel
                  I don't know like Debog ESP32 + MCP2515 with Arduino.
                  On the other hand, is there any other pines for SPI ?
                  • B
                    Bbjodel
                    I don't understand anymore, now it works but I changed the Libraie the same but obviously more complete.
                    I hope it will work in time ...
                    Thank you Felix
