    Cant use GPS and LTE module at the same time
    5 Posts 2 Posters 4.9k Views
      jkeyser
      I have these 2 modules along with the core 2. The LTE module is on pins 14/13, and the gps is on 1/3. LTE module is being powered externally.
      https://shop.m5stack.com/products/gps-module
      https://shop.m5stack.com/collections/m5-modules/products/com-lte-modulesim7600g?variant=35800524488868
      When used separately, everything works fine, but when using both at the same time i get this error as soon as i try to initialize them.
      File "<string>", line 35, in <module>
      File "comx/lte.py, line 27, in __init__
      File "libs/simcom/common.py", line 164, in ...
      IndexError: list index out of range
      • felmueF Online
        Hello @jkeyser
        have you tried to set the GPS module to use GPIOs 5/13 which translates to GPIOs 33 and 19 for M5Core2? (There is a table here (see Pinmap) for the translation.)
          jkeyser @felmue
          just tried, but the same thing happened.
          One thing i did notice was if i initialize the LTE modem first, i dont get the index out of range error, but only the gps works. All the modem status checks such as get_single_quality() get_network_registration() return false as if it isnt even there.
          • felmueF Online
            Hello @jkeyser
            hmm, I wonder if the code internally uses the same Serial for both devices hence the device which is initialized last 'wins'?
            • felmueF Online
              Hello @jkeyser
              BTW: the LTE modem SIM7600G also has a GPS, but you need to add an antenna.
