    SIM7080G CAT-M/NB-IoT+GNSS Unit Issues
    3 Posts 3 Posters 3.7k Views
      KevinMartins
      Hello everyone,
      I come to you because I have a problem with this module, I can not make it work, the UIFlow method does not work nor arduino. When I give him an AT command I have nothing in return. I don’t understand because I have a NB-IoT SIM card that works.
      Can you help me, please?
      • felmueF Online
        Hello @KevinMartins
        which M5 core device are you using? M5Stack (Base, Fire, ...) or M5Core2 or M5CoreS3?
        Also make sure your SIM card has the PIN disabled.
          HappyUser
          #include <HardwareSerial.h>
          HardwareSerial Comm(1);
          Comm.begin(115200, SERIAL_8N1,TX_pin,RX_pin); // TX RX
          Comm.print("AT+IPR=115200\r"); // Set text mode
          Last command should return an OK. If not, it could be that you have mixed up TX and RX pins or a power issue.
          To read the reply from the module you could use something like this :
          while (millis()<wait_until)
          while (Comm.available())
          ccc=Comm.read();
          //Serial.print(ccc);
          if (k<buffer_size-1)
          Receive_buffer[k]=ccc;
          k++;
          Receive_buffer[k]=NULL;
          if (strstr(Receive_buffer,StopCharArray)!=NULL)
          //Serial.println("OK found");
          // SIM7600_Error=0;
          return false;
