    M5Stack ATOM Matrix work with esphome
    1 Posts 1 Posters 2.7k Views
    • L Offline
      leonardo
      I tried to use ATOM Matrix in Ephome,here is a template that i hoping to be helpful to you.
      我尝试在esphome中使用它,可以驱动大部分组件,并接入homeassistant。希望对你有所帮助。
      分别使用了角速度仪、线速度仪(mpu6886),灯板,按钮。均可以在homeassistant中进行操作。
      esphome:
        friendly_name: gradienter
      esp32:
        board: esp32dev
        framework:
          type: arduino
      # Enable logging
      logger:
      # Enable Home Assistant API
      api:
        encryption:
          key: ""
      ota:
        password: "homeassistant"
      wifi:
        ssid: !secret wifi_ssid
        password: !secret wifi_password
        # Enable fallback hotspot (captive portal) in case wifi connection fails
        ap:
          ssid: "Gradienter"
      captive_portal:
      i2c:
        sda: 25
        scl: 21
        scan: true
      sensor:
        - platform: mpu6886
          i2c_id: bus_a
          address: 0x68
          update_interval: 1s
          accel_x:
            name: "MPU6886 Accel X"
          accel_y:
            name: "MPU6886 Accel Y"
          accel_z:
            name: "MPU6886 Accel z"
          gyro_x:
            name: "MPU6886 Gyro X"
          gyro_y:
            name: "MPU6886 Gyro Y"
          gyro_z:
            name: "MPU6886 Gyro z"
          temperature:
            name: "MPU6886 Temperature"
      binary_sensor:
        - platform: gpio
          pin: 39
      light:
        - platform: esp32_rmt_led_strip
          rgb_order: GRB
          pin: 27
          num_leds: 25
          rmt_channel: 0
          chipset: ws2812
          effects:
            # Customize parameters
            - random:
                name: "My Slow Random Effect"
                transition_length: 30s
                update_interval: 30s
            - random:
                name: "My Fast Random Effect"
                transition_length: 4s
                update_interval: 5s
            - pulse:
                transition_length: 0.5s
                update_interval: 0.5s
                min_brightness: 0%
                max_brightness: 100%
            - pulse:
                # transition_length: 1s      # defaults to 1s
                update_interval: 2s
            - random:
                name: Random Effect With Custom Values
                transition_length: 5s
                update_interval: 7s
            - strobe:
                name: Strobe Effect With Custom Values
                colors:
                  - state: true
                    brightness: 100%
                    red: 100%
                    green: 90%
                    blue: 0%
                    duration: 500ms
                  - state: false
                    duration: 250ms
                  - state: true
                    brightness: 100%
                    red: 0%
                    green: 100%
                    blue: 0%
                    duration: 500ms
            - flicker:
                name: Flicker Effect With Custom Values
                alpha: 95%
                intensity: 1.5%
            - addressable_rainbow:
                name: Rainbow Effect With Custom Values
                speed: 10
                width: 50
            - addressable_color_wipe:
                # name: Color Wipe Effect With Custom Values
                # colors:
                #   - red: 100%
                #     green: 100%
                #     blue: 100%
                #     num_leds: 1
                #   - red: 0%
                #     green: 0%
                #     blue: 0%
                #     num_leds: 1
                # add_led_interval: 100ms
                # reverse: false
            - addressable_scan:
                name: Scan Effect With Custom Values
                move_interval: 100ms
                scan_width: 1
            - addressable_twinkle:
                name: Twinkle Effect With Custom Values
                twinkle_probability: 5%
                progress_interval: 4ms
            - addressable_random_twinkle:
                name: Random Twinkle Effect With Custom Values
                progress_interval: 32ms
            - addressable_fireworks:
                name: Fireworks Effect With Custom Values
                update_interval: 32ms
                spark_probability: 10%
                use_random_color: false
                fade_out_rate: 120
      # remote_transmitter:
      #   pin: GPIO12
      #   carrier_duty_percent: 50%  #don't work,don;t use it.
      注意:红外未能成功操作,会出现以下错误,如果知道如何处理还请指导:
      [05:53:02][C][mpu6886:103]:     Accuracy Decimals: 1
      [05:53:02][C][remote_transmitter:015]: Remote Transmitter...
      [05:53:02][C][remote_transmitter:016]:   Channel: 0
      [05:53:02][C][remote_transmitter:017]:   RMT memory blocks: 1
      [05:53:02][C][remote_transmitter:018]:   Clock divider: 80
      [05:53:02][C][remote_transmitter:019]:   Pin: GPIO12
      [05:53:02][C][remote_transmitter:022]:     Carrier Duty: 50%
      [05:53:02][E][remote_transmitter:026]: Configuring RMT driver failed: ESP_ERR_INVALID_STATE
      [05:53:02][C][captive_portal:088]: Captive Portal:
