    SSL Socket errors
    2 Posts 1 Posters 2.6k Views
    • N Offline
      nemsys
      Greetings and thank-you for your time.
      I am trying to send camera images from my ESP32 (M5 Stack PoECAM) to my personal google drive.
      following this tutorial :
      https://hobby-it.com/m5timer_gdrive-2/
      I have setup SSLClient with the EthernetLarge library the jpgs arrive and but they are corrupted/incomplete. Any ideas why this might be happening, I have tried different chunk sizes no effect ?
      I don't believe its hardware as the example sketches all work as intended
      errors/warnings
      SSLClient)(SSL_WARN)(connected): Socket was dropped unexpectedly (this can be an alternative to closing the connection)
      (SSLClient)(SSL_ERROR)(m_print_ssl_error): SSL_CLIENT_WRITE_FAIL
      (SSLClient)(SSL_ERROR)(available): Cannot operate if the write error is not reset:
      The project is on github (https://gitlab.com/ArchNemsys/esp32-poe-cam) the code for the relevant function (sensitive data removed) is posted below apologies I was halfway through refactoring it to use char bufs rather than strings:
      #include <SSLClient.h>
      #include "gdrive_trust.h"
      #define WRITE_SIZE_MAX   1024 //
      //#define API_PORT    443
      //#define API_PATH_TOKEN   "/oauth2/v4/token"
      const char* refreshServer = "oauth2.googleapis.com";
      const char* refreshUri    = "/token";
      const char* apiServer     = "www.googleapis.com";
      const char* apiUri        = "/upload/drive/v3/files?uploadType=multipart";
      char accessToken[2048];
      // ethClient is declared elsewhere but works perfectly outside this funciton
      SSLClient httpsClient(ethClient, gdriveTAs, 1, 25);
      //  SSLClient::write, is buffered does not actually write to the network. you must call SSLClient::available or SSLClient::flush,
      int waitingTime      = 10000; // Wait 10 seconds to google response.
      // Send JPEG by Http POST
      void postGoogleDriveByAPI() {
        Serial.println("Connect to " + String(apiServer));
        if (httpsClient.connect(apiServer, 443)) {
          Serial.println("Connection successful");
          // Get Time for save file name
          struct tm timeinfo;
          if(!getLocalTime(&timeinfo)){
            Serial.println("Failed to obtain time 1");
            return;
          char saveFilename[64];
          char metadata[256];
          const char* startBoundry = "--foo_bar_baz\r\n"
                            "Content-Type:image/jpeg\r\n\r\n";
          const char* endBoundry = "\r\n--foo_bar_baz--";
          strftime (saveFilename,64,"ALERT_%A_%B_%d_%Y_%Hh%Mm%Ss.jpg",&timeinfo);
          Serial.println(saveFilename);
          snprintf( metadata, 256, "--foo_bar_baz\r\n"
                            "Content-Type: application/json; charset=UTF-8\r\n\r\n"
                            "{\"name\":\"%s\",\"parents\":[\"%s\"]}\r\n\r\n" , saveFilename, PARENT_ID );
          unsigned long contentsLength = strlen(metadata) + strlen(startBoundry) + fb->len + strlen(endBoundry);
          snprintf(header,256, "POST %s HTTP/1.1\r\n"
                          "HOST: %s \r\n"
                          "Connection: close\r\n"
                          "content-type: multipart/related; boundary=foo_bar_baz\r\n"
                          "content-length: %u \r\n"
                          "authorization: Bearer %s \r\n\r\n", apiUri, apiServer, contentsLength, accessToken);
          String metadata = "--foo_bar_baz\r\n"
                            "{\"name\":\"" + String(saveFilename) + "\",\"parents\":[\"" + String(PARENT_ID) + "\"]}\r\n\r\n"; // parents:save folder
                            //"{\"name\":\"" + saveFilename + "\"}\r\n\r\n"; // parerents is Optional
          String startBoundry = "--foo_bar_baz\r\n"
          String endBoundry   = "\r\n--foo_bar_baz--";
          unsigned long contentsLength = metadata.length() + startBoundry.length() + fb->len + endBoundry.length();
          String header = "POST " + String(apiUri) + " HTTP/1.1\r\n" +
                          "HOST: " + String(apiServer) + "\r\n" +
                          "Connection: close\r\n" +
                          "content-type: multipart/related; boundary=foo_bar_baz\r\n" +
                          "content-length: " + String(contentsLength) + "\r\n" +
                          "authorization: Bearer " + accessToken + "\r\n\r\n";
          Serial.println("Send JPEG DATA by API");
          httpsClient.print(header);
          httpsClient.print(metadata);
          httpsClient.print(startBoundry);
          // JPEG data is separated into 1000 bytes and POST
          int chunk = 1000;
          unsigned long dataLength = fb->len;
          uint8_t*      bufAddr    = fb->buf;
          for(unsigned long i = 0; i < dataLength ;i=i+chunk) {
            if ( (i + chunk) < dataLength ) {
              httpsClient.write(( bufAddr + i ), chunk);
            } else if (dataLength%chunk != 0) {
              httpsClient.write(( bufAddr + i ), dataLength%chunk);
          httpsClient.print(endBoundry);
          Serial.println("Waiting for response.");
          long int StartTime=millis();
          while (!httpsClient.available()) {
            Serial.print(".");
            delay(100);
            if ((StartTime+waitingTime) < millis()) {
              Serial.println();
              Serial.println("No response.");
              break;
        } else {
          Serial.println("Connected to " + String(refreshServer) + " failed.");
        httpsClient.stop();
      • N Offline
        nemsys
        error found the Framebuffer fb was being freed before the SSLClient could finish writing hence the corrupted drive image.
