    getting started with Core2 and stuck.
    Core 2
    4.4k
    • J
      jmarduino
      Hi
      I just got my hands on a couple Core 2 which I plan to use on my Mac (Intel Core I9, Monterey 12.6.7) with the Arduino environment - both the IDE Version: 2.1.1 and 1.8.19
      I followed the guidelines I found at https://docs.m5stack.com/en/quick_start/core2/arduino to configure my Arduino environment
      When trying to compile a very simple code that does nothing
      void setup() {}
      void loop() {}
      there is no issue, the process works
      but when I try to just add the include for the M5Core2
      #include <M5Core2.h>
      void setup() {}
      void loop() {}
      and try to compile again
      • it first starts OK
      • then I get tons of warnings related to
        missing initializer for member 'GFXfont::smooth_bpp
        or
        warning: missing initializer for member 'GFXfont::range'
      • then it continues
      • then I get more warnings in the RTC code or other modules like
        M5Core2/src/RTC.cpp:221:30: warning: comparison is always true due to limited range of data type
      • then I get a bunch of warning for the fonts such as
        warning: missing initializer for member 'GFXfont::smooth_bpp'
      • and a last one about
        .../M5Core2/src/Fonts/glcdfont.c:10:28: error: 'font' defined but not used [-Werror=unused-const-variable=] static const unsigned char font[] PROGMEM = { ^~~~
        cc1: some warnings being treated as errors
      and then the compilation process ends with
      exit status 1
      Erreur de compilation pour la carte M5Stack-Core2
      I suspect the issue is due to compiler flags as I've seen that report
      How to solve that ?
      Anyone using Core2 in the Arduino environment should be affected if this is the root cause but I could not find specific complaints about this.
      What did I miss?
      thx
      • J
        jmarduino
        answering to myself :
        the issue comes from setting the warnings to max level in the IDE's preferences
        short term fix = drop down the level of warnings to default
        long term fix : fix all the files with a warning. most of them are in the font area.
        I find it surprising the libraries were not tested with all warnings on...
        • N
          NotInTheMafia @jmarduino
          @jmarduino save yourself trouble of converting your code later and use the M5Unified library, not M5Core2.
          • J
            jmarduino @NotInTheMafia
            @notinthemafia thanks for the hint
            • J
              jmarduino @jmarduino
              actually just tried and it has similar issues. If you compile some of the examples with all warnings turned on in the IDE, the compiler stops
              error: unused variable 'names' [-Werror=unused-variable]
                 static constexpr const char* const names[] = { "none", "wasHold", "wasClicked", "wasPressed", "wasReleased", "wasDeciedCount" };
              cc1plus: some warnings being treated as errors
