    lidar lite v3
    M5 Stick/StickC
    8.3k
    • C
      cepics
      Hi all,
      can I connect this Lidar to M5Stick grove connector?
      if yes, I need a voltage divider for SDA and SCL?
      tanks a lot
        ajb2k3 @cepics
        @cepics said in lidar lite v3:
        Hi all,
        tanks a lot
        Technically yes as its i2c but no code will exist.
        • C
          cepics
          Can I try this one?
          #include <Wire.h>
          #include <LIDARLite.h>
          LIDARLite myLidarLite;
           myLidarLite.begin(0, true); // Set configuration to default and I2C to 400 kHz
              configure(int configuration, char lidarliteAddress)
              Selects one of several preset configurations.
              Parameters
              configuration:  Default 0.
                0: Default mode, balanced performance.
                1: Short range, high speed. Uses 0x1d maximum acquisition count.
                2: Default range, higher speed short range. Turns on quick termination
                    detection for faster measurements at short range (with decreased
                    accuracy)
                3: Maximum range. Uses 0xff maximum acquisition count.
                4: High sensitivity detection. Overrides default valid measurement detection
                    algorithm, and uses a threshold value for high sensitivity and noise.
                5: Low sensitivity detection. Overrides default valid measurement detection
                    algorithm, and uses a threshold value for low sensitivity and noise.
              lidarliteAddress: Default 0x62. Fill in new address here if changed. See
                operating manual for instructions.
            myLidarLite.configure(1); // Change this number to try out alternate configurations
            // Take a measurement with receiver bias correction and print to serial terminal
            Serial.println(myLidarLite.distance());
          delay(50);
          best regards
          • C
            cepics @ajb2k3
            @ajb2k3 Hi, trying the sketch above, the serial monitor say:
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            >nack
            the same sketch on esp8266 works!!
            ideas??
            tnks a lot
            • H
              heybin
              hello, gpio sda:21 scl:22, in m5stack red grove
              • C
                cepics @heybin
                @heybin which is the difference between the red I2C (M5Stack) and the white one (M5Stick) ??
                I'm trying on M5Stick....
                • C
                  cepics
                  Hi, all
                  connecting the lidar lite to M5Stick on grove connector makes m5Stick burn!!!
                  this is the sketch:
                  #include <Arduino.h>
                  #include <U8g2lib.h>
                  U8X8_HAVE_HW_SPI
                  #include <SPI.h>
                  #include <Wire.h>
                  #define LedPin 19
                  #define IrPin 17
                  #define BuzzerPin 26
                  #define BtnPin 35
                  int x = 870;
                  int cm;
                  int feet;
                  int inches;
                  int INCHES;
                  bool unit = 0;
                  #include "MPU9250.h"
                  U8G2_SH1107_64X128_1_4W_HW_SPI u8g2(U8G2_R1, /* cs=*/ 14, /* dc=*/ 27, /* reset=*/ 33);
                  // an MPU9250 object with the MPU-9250 sensor on I2C bus 0 with address 0x68
                  MPU9250 IMU(Wire, 0x68);
                  //MPU9250 IMU(Wire,0x71);
                  int status;
                  int orienta;
                  unsigned long pulseWidth;
                    Serial.begin(115200);
                    u8g2.begin();
                    status = IMU.begin();
                    pinMode(25, OUTPUT); // Set pin 2 as trigger pin
                    digitalWrite(25, LOW); // Set trigger LOW for continuous read
                    pinMode(13, INPUT); // Set pin 3 as monitor pin
                    pinMode(BtnPin, INPUT_PULLUP);
                    pinMode(BuzzerPin, OUTPUT);
                    digitalWrite(BuzzerPin, LOW);
                    if (digitalRead(BtnPin) == 0) {
                      unit = !unit;
                      //bounce sound
                      for (int f = 0; f < 500; f++) {
                        digitalWrite(BuzzerPin, HIGH);
                        delay(1);
                        delay(1);
                      pulseWidth = pulseIn(13, HIGH); // Count how long the pulse is high in microseconds
                    // If we get a reading that isn't zero, let's print it
                    if(pulseWidth != 0)
                      pulseWidth = pulseWidth / 10; // 10usec = 1 cm of distance
                      Serial.println(pulseWidth); // Print the distance
                    cm = (pulseWidth) / 10;
                  //  inches = (myData.time + x) / 74 / 2;
                    feet = inches / 12;
                    INCHES = inches % 12; //es x = 7% 5; // X ora contiene 2
                    if (unit) {
                      stampaCM();
                    } else {
                      //stampaFT();
                      stampaCM();
                     // x = 5800 - myData.time ;
                    IMU.readSensor();
                    orienta = IMU.getAccelY_mss();
                    Serial.println("orienta = ");
                    Serial.println(orienta);
                    if (orienta < 0) {
                      u8g2.setFlipMode(1);
                    } else {
                      u8g2.setFlipMode(0);
                    delay(50);
                  void stampaCM() {
                    u8g2.firstPage();
                    do {
                      u8g2.setFont(u8g2_font_7Segments_26x42_mn);
                      if (cm < 10) {
                        u8g2.setCursor(70, 52);
                        u8g2.print(cm);
                      if (cm < 100 && cm >= 10) {
                        u8g2.setCursor(40, 52);
                        u8g2.print(cm);
                      if (cm >= 100) {
                        u8g2.setCursor(20, 52);
                        u8g2.print(cm);
                    } while (u8g2.nextPage());
                  void stampaFT() {
                    u8g2.firstPage();
                    do {
                      u8g2.drawDisc(63, 52, 2, U8G2_DRAW_ALL);
                      if (feet < 10) {
                        u8g2.setCursor(30, 52);
                        u8g2.print(feet);
                      } else {
                        u8g2.setCursor(1, 52);
                        u8g2.print(feet);
                      if (INCHES < 10) {
                        u8g2.setCursor(75, 52);
                        u8g2.print(INCHES);
                      } else {
                        u8g2.setCursor(60, 52);
                        u8g2.print(INCHES);
                  alt text
                  what is this??
                  can I repare it??
                  • H
                    heybin
                    m5stick grove is different, pin is gnd, vcc, 25, 13, those can be viewed from the back of the stick
