    Cardputer serial woes :-(
    Units
    3.0k
    • F
      fentlewoodlewix
      i love my 2 cardputers, have been using them to make maths toys for my youngest kid. recently have run into a problem i dont know how to fix.
      on a razer laptop on ubuntu using the arduino toolchain i uploaded the following code:
      #include "M5Cardputer.h"
      typedef void (*thread_t)(); // define a simple type for a function pointer
      static int constexpr num_threads = 2;
      thread_t threads[num_threads];
      thread_t current_thread;
      void thread_01()
        Serial.println("Thread 01");
        // M5Cardputer.Display.drawString("Thread 01",
        //                               M5Cardputer.Display.width() * 0.25,
        //                             M5Cardputer.Display.height() * 0.25 );
      void thread_02()
        Serial.println("Thread 02");
        // M5Cardputer.Display.drawString("Thread 02",
        //                               M5Cardputer.Display.width() * 0.75,
        //                             M5Cardputer.Display.height() * 0.75 );
      void setup(){
        auto cfg = M5.config();
        M5Cardputer.begin(cfg);
        M5Cardputer.Display.setRotation(1);
        M5Cardputer.Display.setTextColor(GREEN);
        M5Cardputer.Display.setTextDatum(middle_center);
        M5Cardputer.Display.setTextFont(&fonts::FreeSans18pt7b);
        M5Cardputer.Display.setTextSize(1);
        Serial.begin(115200);
        threads[0] = &thread_01;
        threads[1] = &thread_02;
        Serial.println("Main Loop");
        M5Cardputer.Display.drawString("Hello",
                                        M5Cardputer.Display.width() / 2,
                                      M5Cardputer.Display.height() / 2 );
        for ( int n = 0; n< num_threads; n++) {
          threads[n]();
      now when i USB power the device it shows Hello in large friendly letters, but will not accept any new serial uploads from the ardulapino ide or from M5Burner. Though I can see the "Main Loop" text in the serial monitor of the IDE.
      Does anyone here know how to get back from this predicament?
      Thanks,
      Sean
        Hello @fentlewoodlewix
        have you tried to manually set the ESP32S3 into download mode?
        From the documentation: 'To enter the download mode, press the G0 button on StampS3 at boot time.'
        • F
          fentlewoodlewix
          It works now, thank you!
          (I had forgotten about that option)
          • L
            loscuras2 @felmue
            @felmue Hello, even if i follow this commands for me still not working.
              Hello @loscuras2
              have you tried a different USB cable?
