    How to use the fonts available in /Arduino/libraries/M5GFX/src/lgfx/Fonts/GFXFF
    3.1k
      Steve1
      I have used the example "RTC_Clock" from the M5Core_Ink library as attached. The sketch works fine on my M5CoreInk module. I would like to modify the fonts however and I find that only AsciiFont24x48 and AsciiFont8x16 are available to use. Even though some other fonts are available under /Arduino/libraries/M5GFX/src/lgfx/Fonts if I try and use them in place of AsciiFont24x48 in the sketch below I get the error "'FontXXX' was not declared in this scope". How do I declare these additional fonts?
      Also, I have seen that the Library MGFX has lots of fonts under /M5GFX/src/lgfx/Fonts/GFXFF. But I cannot find a simple example of using the M5GFX library to display a text string, any help would be appreciated.
      One final point, if I include the M5GFX library tn the RTC_Clock sketch the compiler complains that AsciiFont24x48 is ambiguous as it has found two versions, how do I fix this?
      #include "M5CoreInk.h"
      #include <WiFi.h>
      #include "time.h"
      const char* ssid             = "YOUR_SSID";
      const char* password         = "YOUR_PASSWORD";
      const char* ntpServer        = "pool.ntp.org";
      const long gmtOffset_sec     = 3600;
      const int daylightOffset_sec = 3600;
      // every hour at minute 45 do a full ink display refresh
      #define FULL_REFRESH_MINUTE (45)
      Ink_Sprite TimePageSprite(&M5.M5Ink);
      void printLocalTimeAndSetRTC() {
          struct tm timeinfo;
          if (getLocalTime(&timeinfo) == false) {
              Serial.println("Failed to obtain time");
              return;
          Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
          RTC_TimeTypeDef time;
          time.Hours   = timeinfo.tm_hour;
          time.Minutes = timeinfo.tm_min;
          time.Seconds = timeinfo.tm_sec;
          M5.rtc.SetTime(&time);
          RTC_DateTypeDef date;
          date.Date  = timeinfo.tm_mday;
          date.Month = timeinfo.tm_mon + 1;
          date.Year  = timeinfo.tm_year + 1900;
          M5.rtc.SetDate(&date);
      void getNTPTime() {
          // Try to connect for 10 seconds
          uint32_t connect_timeout = millis() + 10000;
          Serial.printf("Connecting to %s ", ssid);
          WiFi.begin(ssid, password);
          while ((WiFi.status() != WL_CONNECTED) && (millis() < connect_timeout)) {
              delay(500);
              Serial.print(".");
          if (WiFi.status() != WL_CONNECTED) {
              // WiFi connection failed - set fantasy time and date
              time.Hours   = 6;
              time.Minutes = 43;
              time.Seconds = 50;
              date.Date  = 4;
              date.Month = 12;
              date.Year  = 2020;
              return;
          Serial.println("Connected");
          configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
          printLocalTimeAndSetRTC();
          WiFi.disconnect(true);
          WiFi.mode(WIFI_OFF);
      void drawTimeAndDate(RTC_TimeTypeDef time, RTC_DateTypeDef date) {
          char buf[11];
          snprintf(buf, 6, "%02d:%02d", time.Hours, time.Minutes);
          TimePageSprite.drawString(40, 20, buf, &AsciiFont24x48);
          snprintf(buf, 11, "%02d.%02d.%02d", date.Date, date.Month,
                   date.Year - 2000);
          TimePageSprite.drawString(4, 70, buf, &AsciiFont24x48);
          // Check power on reason before calling M5.begin()
          //  which calls Rtc.begin() which clears the timer flag.
          Wire1.begin(21, 22);
          uint8_t data = M5.rtc.ReadReg(0x01);
          // Green LED - indicates ESP32 is running
          digitalWrite(LED_EXT_PIN, LOW);
          if (M5.M5Ink.isInit() == false) {
              Serial.printf("Ink Init failed");
              while (1) delay(100);
          // Check timer flag
          if ((data & 0b00000100) == 0b00000100) {
              Serial.println("Power on by: RTC timer");
              M5.rtc.GetTime(&time);
              M5.rtc.GetDate(&date);
              // Full refresh once per hour
              if (time.Minutes == FULL_REFRESH_MINUTE - 1) {
                  M5.M5Ink.clear();
          } else {
              Serial.println("Power on by: power button");
              M5.M5Ink.clear();
              // Fetch current time from Internet
              getNTPTime();
          // After every shutdown the sprite is created anew.
          // But the sprite doesn't know about the current image on the
          //  ink display therefore the same time and date, as have been
          //  drawn before the shutdown, are redrawn.
          // This is required, else drawing new time and date only adds
          //  pixels to the already drawn pixels instead of clearing the
          //  previous time and date and then draw the new time and date.
          TimePageSprite.creatSprite(0, 0, 200, 200);
          drawTimeAndDate(time, date);
          TimePageSprite.pushSprite();
          // Wait until full minute, e.g. seconds are 0
          while ((time.Seconds != 0)) {
              delay(200);
          // Draw new time and date
          Serial.printf("Shutdown...\n");
          Serial.flush();
              // Allow extra time for full ink refresh
              // Shutdown for 55 seconds only
              M5.shutdown(55);
              return;
          // Shutdown for 58 seconds
          M5.shutdown(58);
        Steve1
        I have found out how to use the fonts within the M5GFX library;
        #include <Arduino.h>
        #include <M5GFX.h>
        M5GFX display;
          display.begin();
          display.setTextDatum(middle_center);
          uint16_t x = display.width() / 2;
          uint16_t y = display.height() / 2;
          display.setFont(&fonts::FreeMonoBold24pt7b);
          display.drawString("Test", x, y);
