    microPython on esp32 C3 mate error InvalidPin when use GP19 for relay.
    3 Posts 3 Posters 4.0k Views
      Sebastien Jourdan
      User
      With microPython on esp32 C3 mate, I would like to use a 3A Relay unit, for that I use GP19 which are also dedicate for USA D+, with the following code:
      '''python3
      import machine
      relay = machine.Pin("GP19", machine.Pin.OUT)
      if temp > 42:
      relay.value(1)
      elif temp < 40:
      relay.value(0)
      else:
      pass
      But I have this error:
      File "main.py", line 7, in <module>
      ValueError: invalid pin
      Do you know why?
      Is it possible to use GP19 for a relay even if this Pin is dedicate to USA D+?
      Thanks you,
      Sebastien
      • stjofrS Offline
        stjofr
        Why don't you use the 1st argument (pin number) in integer format ?
        Stef Code
        Project Management Director and Editor
        in Database Software Systems Development
        https://stjo.fr
          the GP is not required, only numbers are required.
