    Help needed with SERVO Module Board 12 Channels
    Modules
    1.4k
    • W
      wwhite
      Does anyone have a working example for the SERVO Module Board 12 Channels? I'm using the code below with single servo on port 1 and all I get when I run this code is "Servo Example" written across the M5Core screen but no movement whatsoever from the servo. Note the ports on the module are 0 thru 11 and my servo is plugged into 1 because the pins on port zero are too close to the module case to get my servo plug in anywhere on that row.
      Also, for the to Servo_write_angle(uint8_t number, uint16_t us) and Servo_write_us(uint8_t number, uint16_t us) is number the port number (0..11)?
      Thanks in advance.
      #include <Arduino.h>
      #include <M5Stack.h>
      #include <Wire.h>
      #define SERVO_ADDR 0x53
      M5.begin(true, false, true);
      M5.Power.begin();
      M5.Lcd.setTextFont(4);
      M5.Lcd.setCursor(70, 100);
      M5.Lcd.print("Servo Example");
      Wire.begin(21, 22, 100000UL);
      // addr 0x01 mean control the number 1 servo by us
      void Servo_write_us(uint8_t number, uint16_t us) {
      Wire.beginTransmission(SERVO_ADDR);
      Wire.write(0x00 | number);
      Wire.write(us & 0x00ff);
      Wire.write(us >> 8 & 0x00ff);
      Wire.endTransmission();
      // addr 0x11 mean control the number 1 servo by angle
      void Servo_write_angle(uint8_t number, uint8_t angle) {
      Wire.write(0x10 | number);
      Wire.write(angle);
      for (uint8_t i = 0; i < 12; i++) {
      //Servo_write_us(i, 700);
      Servo_write_angle(i, 0);
      delay(1000);
      //Servo_write_us(i, 2300);
      Servo_write_angle(i, 90);
      delay(1000);
