    Displaying an image on a Core2
    Core 2
    2.2k
    • P
      PaulB
      Hi All,
      I have tried multiple ways to display an image on my Core2, it either does not compile or the image is display as a distorted mess.
      I am able to display the image on an ESP32 development board connected to 1.3" OLED using the Adafruit Graphic library, so I am not sure if I need to "recreate" the "hex map", I have tried Ricky-Dink online convertor and again, my code refuses to compile.
      I have searched the forum and so far have not found any guidance, I am using the M5 Unified.h and not Core2.h
      Any guidance would be most appreciated.
      Kind Regards
      Paul
        The information is about somewhere but on the ESP32 ports for M5Stack, Images must be smaller then a certain file size and the save format must be of a certain format. I you search Github for my UIFlow Handbook, you will find this data in the PDF.
