    Core2 with 4 Relay UNIT, example code crashes
    2 Posts 2 Posters 2.5k Views
      Pugmartin
      Hi there,
      Using the Arduino example sketch for the 4 Relay UNIT (not the MODULE) my Core2 constantly crashes / reboots on an endless loop. It does appear to get through most of the setup code before rebooting. ie the LCD will display until I'm guessing it hits the 'relay.Init(0);' line and this brings everything to a halt.
      The stranger thing is though that this happens IF I'm lucky enough to get the compiled code to the Core2 - if I compile/upload again there's a 50/50 chance the compiler will error on:
      ...\AppData\Local\Temp\.arduinoIDE-unsaved20231020-21796-14ea59g.a188\Unit_4RELAY_M5Core2\Unit_4RELAY_M5Core2.ino: In function 'void loop()':
      ...\AppData\Local\Temp\.arduinoIDE-unsaved20231020-21796-14ea59g.a188\Unit_4RELAY_M5Core2\Unit_4RELAY_M5Core2.ino:100:23: error: 'class UNIT_4RELAY' has no member named 'LED_ALL'
                       relay.LED_ALL(1);  // Turn on all the lights. 打开所有的灯
      ...\AppData\Local\Temp\.arduinoIDE-unsaved20231020-21796-14ea59g.a188\Unit_4RELAY_M5Core2\Unit_4RELAY_M5Core2.ino:106:23: error: 'class UNIT_4RELAY' has no member named 'LED_ALL'
                       relay.LED_ALL(0);  // Turn off all the lights.  关闭所有的灯
      Compilation error: 'class UNIT_4RELAY' has no member named 'LED_ALL'
      If I continue to compile after a time it will finish & upload, but then crash as above.
      I'm only here after running into problems with the same 4 Relay UNIT with the Cardputer - the same happened there so I thought hang on, I'll try with my Core2 lying around and see how that works, and bring it back to the Cardputer from there... no luck!
      * Copyright (c) 2021 by M5Stack
      *                  Equipped with M5Core2 sample source code
      *                          配套  M5Core2 示例源代码
      * Visit for more information: https://docs.m5stack.com/en/unit/4relay
      * 获取更多资料请访问: https://docs.m5stack.com/zh_CN/unit/4relay
      * Product: Unit 4RELAY.
      * Date: 2022/7/22
        Please connect to port A,Control 4 relays and demonstrate the asynchronous
      control relay LED 请连接A端口,控制4继电器,并演示异步控制继电器LED
        RELAY control reg           | 0x10
        Relay_ctrl_mode_reg[0]      | R/W | System control
                                    | 7 | 6 | 5 | 4 | 3 | 2 | 1 |     0     |
                                    | R | R | R | R | R | R | R | Sync Mode |
                                    | -Sync Mode:0 LED&Relay Async
                                    | -Sync Mode:1 LED&Relay Sync
        Relay_ctrl_mode_reg[1]      | R/W | Relay & LED control
                                    | LED1| LED2| LED3| LED4| RLY1| RLY2| RLY3| RLY4|
      // Note: The relay can only be controlled in synchronous mode, if the relay is
      // controlled in asynchronous mode, it will be invalid.
      // 注意:只能在同步模式下控制继电器,如果在异步模式下对继电器进行控制将无效,.
      #include <M5Core2.h>
      #include "Unit_4RELAY.h"
      UNIT_4RELAY relay;
          M5.begin(true, false, true, true);  // Init M5Core2 And the I2C port(21,22).
                                              // 初始化 M5Core2 和I2C(21,22)端口
          M5.Lcd.setCursor(
              80, 0, 4);  // Set the cursor position to (80,0). 将光标位置设置为(80,0)
          M5.Lcd.print("4-RELAY UNIT\n\n");
          M5.Lcd.print("   Relay State: \n   Sync Mode: ");
          M5.Lcd.setCursor(0, 220, 2);
          M5.Lcd.print("Independent switch  Sync/Async    ALL relay");
          relay.Init(0);  // Set the lamp and relay to asynchronous mode(Async =
                          // 0,Sync = 1).  将灯和继电器设为非同步模式
      char count_i   = 0;
      bool sync_flag = 0, all_flag = 0;
          M5.update();  // Check button down state.  检测按键按下状态
          if (M5.BtnA.wasPressed()) {  // If button A is pressed.  如果按键A按下
              M5.Lcd.fillRect(160, 50, 100, 20, BLACK);
              M5.Lcd.setCursor(160, 50, 4);
              if (count_i < 4) {
                  M5.Lcd.printf("%d ON", count_i + 1);
                  if (sync_flag) {
                      relay.relayWrite(
                          count_i,
                          1);  // Open the relay at Count_i.  打开count_i处的继电器
                  } else
                      relay.ledWrite(count_i,
                                     1);  // Turn on count_I to get led lights.
                                          // 打开count_i出得led灯
              } else {
                  M5.Lcd.printf("%d OFF", (count_i - 3));
                  if (sync_flag) {
                      relay.relayWrite(
                          (count_i - 4),
                          0);  // Close the relay at Count_i.  关闭count_i处的继电器
                  } else
                      relay.ledWrite(
                          (count_i - 4),
                          0);  // Turn off the COUNt_I leds.  关闭count_i出得led灯
              count_i++;
              if (count_i >= 8) count_i = 0;
          } else if (M5.BtnB.wasPressed()) {
              sync_flag = !sync_flag;
              relay.switchMode(sync_flag);
              M5.Lcd.fillRect(160, 80, 100, 20, BLACK);
              M5.Lcd.setCursor(160, 80, 4);
              if (!sync_flag) {
                  M5.Lcd.print("Async");
              } else {
                  M5.Lcd.print("Sync");
          if (M5.BtnC.wasPressed()) {
              all_flag = !all_flag;
              if (all_flag) {
                  M5.Lcd.printf("ALL.ON ");
                  if (sync_flag)
                      relay.relayAll(1);  // Open all the relays.  打开所有的继电器
                  else
              } else {
                  M5.Lcd.printf("ALL.OFF");
                  if (sync_flag)
                      relay.relayAll(0);  // Close all relays.  关闭所有的继电器
                  else
      Any ideas would be much appreciated.
        Hello @Pugmartin
        you are correct, the example is broken in at least two ways. Firstly it doesn't compile and secondly a statement is missing.
        I had success compiling using the example here.
        To fix the crash it needs a small fix in setup() - add this line before relay.init(0):
        relay.begin();  // new line
        relay.init(0);  // existing line
