    UIFlow infinite loop and code reload
    UIFlow
    3.3k
    • B
      b0rscht
      After creating an infinite loop in UIFlow, and executing it. I am unable to then execute new code subsequently. UIFlow says 'Execute code successfully', but state of the device does not change. The only solution I found was to power-cycle the device. Are there any software workarounds?
      HW: Atom Lite.
      SW: v1.12.9
      WEB: 2023.12.8 https://flow.m5stack.com/
        You need to add a while loop which is the yellow main program loop and code needs to be placed in that
        You should be using a button loop for this.
        • P
          pandian.nano
          Hi @b0rscht ,
          You should add this loop (yellow color) because it has included a 2ms delay or you use to while loop inside add the 2ms delay
          (OR)
