    M5StampS3 / M5Dial and CAN
    4 Posts 2 Posters 4.7k Views 1 Watching
      samarkh
      Has anyone got the CAN unit to work with the ESP32 S3 devices?
      I end up with a load of compiled messages when I try using the ported Atom examples using Platformio
      It looks like the problem is in CAN.c and the TWAI driver
      see
      https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/twai.html
      Error Messages
      "In file included from C:/Users/simon/.platformio/packages/framework-arduinoespressif32@src-e2e946657dbcd16e4aabb8a644a06175/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_reg.h:21,
      from src/CAN.c:38:
      src/CAN.c: In function 'CAN_init':
      src/CAN.c:169:29: error: 'DPORT_PERIP_CLK_EN_REG' undeclared (first use in this function); did
      you mean 'SYSTEM_PERIP_CLK_EN1_REG'?
      DPORT_SET_PERI_REG_MASK(DPORT_PERIP_CLK_EN_REG, DPORT_CAN_CLK_EN);
      C:/Users/simon/.platformio/packages/framework-arduinoespressif32@src-e2e946657dbcd16e4aabb8a644a06175/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:75:67: note: in definition of macro '_DPORT_WRITE_PERI_REG'
      #define _DPORT_WRITE_PERI_REG(addr, val) (*((volatile uint32_t )(addr))) = (uint32_t)(val)
      C:/Users/simon/.platformio/packages/framework-arduinoespressif32@src-e2e946657dbcd16e4aabb8a644a06175/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:88:46: note: in expansion of macro 'DPORT_WRITE_PERI_REG'
      #define DPORT_SET_PERI_REG_MASK(reg, mask) DPORT_WRITE_PERI_REG((reg), (DPORT_READ_PERI_REG(reg)|(mask)))
      src/CAN.c:169:5: note: in expansion of macro 'DPORT_SET_PERI_REG_MASK'
      src/CAN.c:169:29: note: each undeclared identifier is reported only once for each function it appears in
      src/CAN.c:169:53: error: 'DPORT_CAN_CLK_EN' undeclared (first use in this function); did you mean 'DPORT_REG_CLR_BIT'?
      C:/Users/simon/.platformio/packages/framework-arduinoespressif32@src-e2e946657dbcd16e4aabb8a644a06175/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:75:88: note: in definition of macro '_DPORT_WRITE_PERI_REG'
      src/CAN.c:170:31: error: 'DPORT_PERIP_RST_EN_REG' undeclared (first use in this function); did
      you mean 'SYSTEM_PERIP_RST_EN0_REG'?
      DPORT_CLEAR_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG, DPORT_CAN_RST);
      C:/Users/simon/.platformio/packages/framework-arduinoespressif32@src-e2e946657dbcd16e4aabb8a644a06175/tools/sdk/esp32s3/include/soc/esp32s3/include/soc/dport_access.h:85:46: note: in expansion of macro 'DPORT_WRITE_PERI_REG'
      #define DPORT_CLEAR_PERI_REG_MASK(reg, mask) DPORT_WRITE_PERI_REG((reg), (DPORT_READ_PERI_REG(reg)&(~(mask))))
      src/CAN.c:170:5: note: in expansion of macro 'DPORT_CLEAR_PERI_REG_MASK'
      src/CAN.c:170:55: error: 'DPORT_CAN_RST' undeclared (first use in this function); did you mean
      'DPORT_DATE_REG'?
      src/CAN.c:175:40: error: 'CAN_TX_IDX' undeclared (first use in this function); did you mean 'TWAI_TX_IDX'?
      gpio_matrix_out(CAN_cfg.tx_pin_id, CAN_TX_IDX, 0, 0);
      TWAI_TX_IDX
      src/CAN.c:180:39: error: 'CAN_RX_IDX' undeclared (first use in this function); did you mean 'TWAI_RX_IDX'?
      gpio_matrix_in(CAN_cfg.rx_pin_id, CAN_RX_IDX, 0);
      TWAI_RX_IDX
      src/CAN.c:252:20: error: 'ETS_CAN_INTR_SOURCE' undeclared (first use in this function)
      esp_intr_alloc(ETS_CAN_INTR_SOURCE, 0, CAN_isr, NULL, NULL);
      Compiling .pio\build\m5stack-stamps3\src\main.cpp.o
      Compiling .pio\build\m5stack-stamps3\lib421\ESP32CAN\CAN.c.o
      In file included from .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:37:
      C:/Users/simon/.platformio/packages/framework-arduinoespressif32@src-e2e946657dbcd16e4aabb8a644a06175/tools/sdk/esp32s3/include/esp_hw_support/include/esp_intr.h:8:2: warning: #warning esp_intr.h is deprecated, please include esp_intr_alloc.h instead [-Wcpp]
      from .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:38:
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c: In function 'CAN_init':
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:173:26: error: 'DPORT_PERIP_CLK_EN_REG' undeclared (first use in this function); did you mean 'SYSTEM_PERIP_CLK_EN1_REG'?
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:173:2: note: in expansion of macro 'DPORT_SET_PERI_REG_MASK'
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:173:26: note: each undeclared identifier is reported only once for each function it appears in
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:173:50: error: 'DPORT_CAN_CLK_EN' undeclared (first use in this function); did you mean 'DPORT_REG_CLR_BIT'?
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:174:28: error: 'DPORT_PERIP_RST_EN_REG' undeclared (first use in this function); did you mean 'SYSTEM_PERIP_RST_EN0_REG'?
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:174:2: note: in expansion of macro 'DPORT_CLEAR_PERI_REG_MASK'
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:174:52: error: 'DPORT_CAN_RST' undeclared (first use in this function); did you mean 'DPORT_DATE_REG'?
      ((volatile uint32_t *)(addr))) = (uint32_t)(val)
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:179:37: error: 'CAN_TX_IDX' undeclared (first use in this function); did you mean 'TWAI_TX_IDX'?
      TWAI_TX_IDX
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:184:36: error: 'CAN_RX_IDX' undeclared (first use in this function); did you mean 'TWAI_RX_IDX'?
      TWAI_RX_IDX
      .pio/libdeps/m5stack-stamps3/ESP32CAN/src/CAN.c:254:17: error: 'ETS_CAN_INTR_SOURCE' undeclared (first use in this function)
      *** [.pio\build\m5stack-stamps3\src\CAN.c.o] Error 1
      *** [.pio\build\m5stack-stamps3\lib421\ESP32CAN\CAN.c.o] Error 1
      ================================= [FAILED] Took 16.27 seconds ================================="
      Source code
      • @file encoder.ino
      • @author SeanKwok (shaoxiang@m5stack.com)
      • @brief M5Dial Encoder Test
      • @version 0.2
      • @date 2023-10-18
      • @Hardwares: M5Dial
      • https://shop.m5stack.com/products/m5stack-dial-esp32-s3-smart-rotary-knob-w-1-28-round-touch-screen
      • https://docs.m5stack.com/en/core/M5Dial
      • https://github.com/m5stack/M5Dial
      • @Platform Version: Arduino M5Stack Board Manager v2.0.7
      • @Dependent Library:
      • M5GFX: https://github.com/m5stack/M5GFX
      • M5Unified: https://github.com/m5stack/M5Unified
      • CANBus Unit(CA-IS3050G) Grove cable connected
      • https://shop.m5stack.com/products/canbus-unitca-is3050g
      • https://docs.m5stack.com/en/unit/can?ref=kmjp2x8a
      • https://github.com/m5stack/M5Stack/tree/master/examples/Unit/CAN
      #include "M5Dial.h"
      #include <M5Unified.h>
      #include <M5GFX.h>
      #include <ESP32CAN.h>
      #include <CAN_config.h>
      #include "driver/twai.h"
      /****** comment out to make sender ********/
      #define CAN_RECIEVER // Remove to make sender
      #define Use_PortB // Remove to use Port A (Red)
      #define CAN_MSG_ID 0x001
      CAN_device_t CAN_cfg; // CAN Config.
      unsigned long previousMillis = 0; // will store last time a CAN Message was sent // send. 将存储上次发送CAN消息的时间。
      const int interval = 80; // interval at which send CAN Messages (milliseconds).
      const int rx_queue_size = 10; // Receive Queue size.
      int LedNumberCount = 0;
      int waitCANData = 0;
      uint8_t msgcnt = 0;
      void setup()
      auto cfg = M5.config();
      M5Dial.begin(cfg, true, false);
      M5Dial.Display.setTextColor(GREEN);
      M5Dial.Display.setTextDatum(middle_center);
      M5Dial.Display.setFont(&fonts::Orbitron_Light_32);
      M5Dial.Display.setTextSize(1);
              M5Dial.Display.drawString(String("Dial CAN"), M5Dial.Display.width() / 2, M5Dial.Display.height() / 2);
      M5.Lcd.println("M5Stack Core2 and CAN Bus adaptor");  // Print a string on the screen.
      M5.Lcd.setTextColor(ORANGE);
      // M5.Lcd.println("* sending a string to be converted to upper case, ");
      // M5.Lcd.println("
      receiving response and display it on Terminal. *");
      Serial.println("Basic Demo - ESP32-Arduino-CAN");
      Serial.println("M5Stack CoreS3 and CAN Bus adaptor");
      Serial.println("*  sending a string to be converted to upper case,  *");
      Serial.println("*  receiving response and display it on a Terminal. *");
      /* set CAN pins */
      // GROVE connector GPIO pins
      #ifdef Use_PortB
      // Port B
      CAN_cfg.tx_pin_id = GPIO_NUM_1; //
      CAN_cfg.rx_pin_id = GPIO_NUM_2;
      #else
      // Port A Red Port (Shared with I2C)
      CAN_cfg.tx_pin_id = GPIO_NUM_15; // SCL
      CAN_cfg.rx_pin_id = GPIO_NUM_13; // SDA
      #endif
      CAN_cfg.speed = CAN_SPEED_500KBPS;
      CAN_cfg.rx_queue  = xQueueCreate(rx_queue_size, sizeof(CAN_frame_t));
      ESP32Can.CANInit();
      Serial.println("CAN Installed");
      #ifdef CAN_RECIEVER
      Serial.println("Set as RECIEVER");
      //M5.Lcd.println("* Set as RECIEVER ");
      #else
      Serial.println("Set as SENDER");
      M5.Lcd.println("
      Set as SENDER *");
      #endif
      void loop()
      unsigned long currentMillis = millis();
      #ifdef CAN_RECIEVER
      // recieve CAN Message
      CAN_frame_t rx_frame;
      if (xQueueReceive(CAN_cfg.rx_queue, &rx_frame, 3 * portTICK_PERIOD_MS) ==  pdTRUE)
          if (rx_frame.FIR.B.FF == CAN_frame_std)
              Serial.printf("New standard frame");
          else
              Serial.printf("New extended frame");
          if (rx_frame.FIR.B.RTR == CAN_RTR)
              Serial.printf(" RTR from 0x%08X, DLC %d\r\n", rx_frame.MsgID, rx_frame.FIR.B.DLC);
          else
              Serial.printf(" from 0x%08X, DLC %d, Data ", rx_frame.MsgID, rx_frame.FIR.B.DLC);
              for (int i = 0; i < rx_frame.FIR.B.DLC; i++)
                  Serial.printf("0x%02X ", rx_frame.data.u8[i]);
              Serial.printf("\n");
              if (rx_frame.data.u8[0] == 0x01)
                  CAN_frame_t tx_frame;
                  tx_frame.FIR.B.FF   = CAN_frame_std;
                  tx_frame.MsgID      = CAN_MSG_ID;
                  tx_frame.FIR.B.DLC  = 8;
                  tx_frame.data.u8[0] = 0x02;
                  tx_frame.data.u8[1] = rx_frame.data.u8[1];
                  tx_frame.data.u8[2] = 0x00;
                  tx_frame.data.u8[3] = 0x00;
                  tx_frame.data.u8[4] = 0x00;
                  tx_frame.data.u8[5] = 0x00;
                  tx_frame.data.u8[6] = 0x00;
                  tx_frame.data.u8[7] = 0x00;
                  ESP32Can.CANWriteFrame(&tx_frame);
      #else
      // Send CAN Message
      if (currentMillis - previousMillis >= interval)
      ESP32Can.CANInit();
      previousMillis = currentMillis;
      tx_frame.data.u8[0] = 0x01;
      tx_frame.data.u8[1] = msgcnt;
           ESP32Can.CANStop();
          msgcnt++;
          if (msgcnt > 29)
              msgcnt = 0;
          else
          else
              if (rx_frame.data.u8[0] == 0x02)
                      if (rx_frame.data.u8[1] < 25)
                      Serial.println("x");
                      //M5.dis.drawpix(rx_frame.data.u8[1], CRGB(100, 0, 0));
                  else if (rx_frame.data.u8[1] > 27)
                      Serial.println("y");
                      //M5.dis.fillpix(CRGB(0, 0, 20));
                  waitCANData = 0;
      #endif
      // waitCANData
      M5.update();
      if (M5.BtnA.isPressed())
      M5.Lcd.fillScreen(YELLOW);
      esp_restart();
      delay(10);
      Platformio.ini
      ; PlatformIO Project Configuration File
      ; Build options: build flags, source filter
      ; Upload options: custom upload port, speed and extra flags
      ; Library options: dependencies, extra library storages
      ; Advanced options: extra scripting
      ; Please visit documentation for the other options and examples
      ; https://docs.platformio.org/page/projectconf.html
      [env:m5stack-stamps3]
      platform = espressif32
      board = m5stack-stamps3
      framework = arduino
      lib_deps =
      m5stack/M5Dial@^1.0.2
      m5stack/M5Unified@^0.1.11
      m5stack/M5GFX@^0.1.11
      miwagner/ESP32CAN@^0.0.1
      platform_packages = framework-arduinoespressif32@https://github.com/espressif/arduino-esp32/archive/refs/tags/2.0.14.zip
      lib_ldf_mode = deep+
      upload_speed = 1500000
      upload_port = COM7
      monitor_speed = 115200
      monitor_port = COM7
        Hello @samarkh
        it looks like the CAN library is not compatible with the S3 variant used in M5Dial. See here.
          samarkh
          Hi Felix
          Do you know if there is any plan to develop/recommend one as the M5Dial is perfect for Automotive applications?
          Yours Simon M.
            Hello @samarkh
            sorry, no idea when and if such a library will be developed.
            That said, maybe this example helps?
