    Micropython, CardComputer - issue reading Keyboard
    Micropython
    micropython
    5
    8
    7.3k
    • MartynWM
      MartynW
      Hi, I've sucessfully installed the most recent ESP32S3 build of Micropython on my M5Stack CardComputer. Due to it being a generic build, there are no specific device drivers included with the firmware; however, I've managed to get some integrated peripherals working, ie the LCD, sdCard.
      The keyboard (schematic) in giving me some problems, its a pretty standard key matrix, the rows are provides using a 74hc138 3-8 line decoder, and the columns are 7 GPIOs. The outputs from the decoder are active low (datasheet), so I made the column pins inputs with pullups - doesnt work, needs pulldowns????
      Reading the column pins whilst iterating through the 8 rows should allow the individual key detection, but although key presses yield a pin change it doesn't work as expected and column 2 is always high???
          from time import sleep_ms
          from machine import Pin
           M5Stack CardComputer Keyboard
           74HC138 3 to 8 line decoder
           Decoder Pin   A2, A1, A0   ----\    Y6, Y5, Y4, Y3, Y2,  Y1,  Y0
           GPIO Pin     G11, G9, G8   ----/    G7, G6, G5, G4, G3, G15, G13
          class KeyBoard():
              def __init__(self):
                  keyPins = [ ('C0', 13, Pin.IN, Pin.PULL_DOWN), ('C1', 15, Pin.IN, Pin.PULL_DOWN), ('C2', 3, Pin.IN, Pin.PULL_DOWN),
                              ('C3',  4, Pin.IN, Pin.PULL_DOWN), ('C4',  5, Pin.IN, Pin.PULL_DOWN), ('C5', 6, Pin.IN, Pin.PULL_DOWN),
                              ('C6',  7, Pin.IN, Pin.PULL_DOWN),
                              ('A0',  8, Pin.OUT, None), ('A1', 9, Pin.OUT, None), ('A2', 11, Pin.OUT, None) ]
                  ap = dict()
                  for (name, pin, direction, pull) in keyPins:
                      self.pinMap[name] = Pin(pin, direction, pull)
              def scan(self):
                  for row in range(0,8):
                      self.pinMap['A0'].value( row & 0b001 )
                      self.pinMap['A1'].value( row & 0b010 >> 1 )
                      self.pinMap['A2'].value( row & 0b100 >> 2 )
                      sleep_ms(250)
                      print(f'{row:04b}\t',end='')
                      for col in ['C0', 'C1', 'C2', 'C3', 'C4', 'C5', 'C6']:
                          sleep_ms(0)
                          val = self.pinMap[col].value()
                          print(f'{val:01b} ', end='')
                      print('')
                  print('\n\n\n\n')
      keyboard = KeyBoard()
      while True:
          keyboard.scan()
          sleep_ms(500)
      Any ideas of where I'm going wrong??
        Hello @MartynW
        I tried your code and changed two things to make it work:
        • changed the inputs to pullups (as you already thought it should be) - the output matrix then is all 1s except for the button pressed.
        • used some additional brackets for A1 and A2 to force the AND operation to happen first
                    self.pinMap['A1'].value( ( row & 0b010 ) >> 1 )
                    self.pinMap['A2'].value( ( row & 0b100 ) >> 2 )
        Full code:
        class KeyBoard():
            def __init__(self):
              keyPins = [ ('C0', 13, Pin.IN, Pin.PULL_UP), ('C1', 15, Pin.IN, Pin.PULL_UP), ('C2', 3, Pin.IN, Pin.PULL_UP),
                          ('C3',  4, Pin.IN, Pin.PULL_UP), ('C4',  5, Pin.IN, Pin.PULL_UP), ('C5', 6, Pin.IN, Pin.PULL_UP),
                          ('C6',  7, Pin.IN, Pin.PULL_UP),
              self.pinMap = dict()
            def scan(self):
                    sleep_ms(250)
                        sleep_ms(0)
                    print('')
                print('\n\n\n\n')
            def scan2(self):
                for row in (7, 3, 6, 2, 5, 1, 4, 0):
                    sleep_ms(250)
                        sleep_ms(0)
                    print('')
                print('\n\n\n\n')
        while True:
            keyboard.scan()
        #    keyboard.scan2()
            sleep_ms(500)
        BTW: I like your coding style with the pinMap etc. (Note: I am not very familiar with Micropython.)
        MartynWM 1 Reply Last reply Reply Quote 1
        • MartynWM
          MartynW @felmue
          Felix,
          Thank you for the extra pair of eyes much appreciated, I got so obsessed with the PULL_UP/PULL_DOWN issue, I didn't even consider the processing order of the bitwise logic!! Many thanks.
          Martyn
          • F
            felipeparaizo @MartynW
            Hello @martynw, I've been trying for a while to get my CardComputer's screen to work with Micropython code. I want to display a simple "hello world," but I'm having trouble. Could you help me? Could you show your code for activating the screen and writing anything on it?
            • T
              thijsnl
              Hello MartynW
              how do you use just the machine library. When I try this the m5stack gives an error.
              When I use the m5stack lib I don't have any problems with this
                ajb2k3 @thijsnl
                @felipeparaizo said in Micropython, CardComputer - issue reading Keyboard:
                Have you added a driver to control the screen?
                @thijsnl said in Micropython, CardComputer - issue reading Keyboard:
                Hello MartynW
                What's is the error?
                • F
                  felipeparaizo
                  @ajb2k3 said in Micropython, CardComputer - issue reading Keyboard:
                  Você adicionou um driver para controlar a tela?
                  Não, qual seria esse driver ? como posso adicionar ?
                    Você precisa fazer upload do driver Micropython para a tela ST7789V2 no micropython usando thonny.
