    Tools: ampy reloaded
    PROJECTS
    5.5k
    • F
      felix42eu
      ampy is a great console script implemented in Python to conntect to the M5/Micropython Devices via serial terminal
      NOTE: so this will not work if another tool (like putty) already using the serial port!
      The following command (in windows style) would print the content of the file boot.py from the system on the command line
      ampy -p COM1 get /flash/boot.py
      Use the following to write a new file
      ampy -p COM1 get /flash/boot.py  boot.py
      that is
      ampy -p {{port}} get  {{remote_file_path}}  {{local_file_path}}
      To put a file on the device you have to write
      ampy -p COM1 put boot.py /flash/boot.py
      that is
      ampy -p {{port}}  put {{local_file_path}} {{remote_file_path}}
      There are some ideas for improvement of the process of ampy:
      1. the serial port would better be read from a configuration file, hence it often the same entry
      you may use the environment variable AMPY_PORT, AMPY_BAUD... but this is a little bit too static
      you can find my test code on the forked repository https://github.com/ahaeberle/ampy
      1. add default path for local files and write them without giving the name on a second parameter
      from the system on the command line to write a new file.
      remember to put the an ampy.json in the folder or use a --json {{filename}}
      ampy get /flash/boot.py  # with implicit filename
      1. add default path for remote files to put them with a simpler command
      new command to get a file with an ampy.json in the calling directory
      that is
      ampy get  {{remote_file_path}}  # implicit name and path with json
      and the JSON-File
          "AMPY_PORT": "COM1",
          "AMPY_DELAY":     0.0,
          "AMPY_BAUD": 115200,
          "REMOTE_PATH": "/flash/",
          "LOCAL_PATH": "./"
      • F
        felix42eu
        there is a small mistake in the last commands:
        ampy put boot.py
        that is
        ampy put {{local_file_path}} # implicit remote path and name with json
        and the JSON-File
