    Are there any good tutorials out there for the atom s3 light?
    General
    1.2k
    • R
      rob.driver1970
      Are there any good tutorials out there for the atom s3 light? I haven't had any luck getting it to run anything, not even a simple LED color change. I would love to be able to just push sensor values over MQTT but I can't even do the simplest of task. I set up Core 2s with UIFlow 1.0 with no problems but version 2.0 is a different animal. If anyone knows of some example code out there it would be much appreciated. Wanting to eventually read an RFID card and push the number across MQTT.
      • robskiR
        robski
        re: MQTT in uiflow2 and my M5core I had to use "execute code" way to configure MQTT
        the way it worked in uiflow1 was not working in uiflow2 - im using Hive services for MQTT btw
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
        • robskiR
          robski
          some examples on github - same as with library - thats for arduino tho
          AtomS3 github
