    Atom Matrix with FW 1.13.1 not connecting to AWS
    13 Posts 2 Posters 9.1k Views
      chr1g1
      Hi all,
      I struggle to get my m5stack Atom Matrix to connect to AWS. I double checked the AWS setup including the policy etc. There seem to be a problem with the connection I always get the following error when trying to publish something:
      [45944] MQTTException -> [Errno 9] EBADF
      reconnect start ...
      reconnect finish ...
      [48536] MQTTException -> [Errno 9] EBADF
      reconnect start ...
      It also seems there changed some things recently. All examples I find are with a block called "dump to json" but this is no longer available. I work with "create JSON (string) and keys. See the picture.
      Code is here:
      from m5stack import *
      from m5ui import *
      from uiflow import *
      from IoTcloud.AWS import AWS
      from libs.json_py import *
      import time
      import unit
      rgb.set_screen([0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0])
      tvoc_0 = unit.get(unit.TVOC, unit.PORTA)
      eCO2 = None
      TVOC = None
      H2 = None
      Ethanol = None
      aws = AWS(things_name='CO2Sensor', host='xxxxxxxxxxx-ats.iot.eu-central-1.amazonaws.com', port=8883, keepalive=60, cert_file_path="/flash/res/co22-certificate.pem.crt", private_key_path="/flash/res/co22-private.pem.key")
      aws.start()
      print('AWS started')
      while True:
      eCO2 = tvoc_0.eCO2
      TVOC = tvoc_0.TVOC
      H2 = tvoc_0.H2
      Ethanol = tvoc_0.Ethanol
      aws.publish(str('$aws/things/CO2Sensor/co2'),str((py_2_json({'eCO2':eCO2,'TVOC':TVOC,'H2':H2,'Ethanol':Ethanol}))))
        chr1g1
        Meanwhile I upgraded to 1.13.2 and still got the same error.
        I then added the AWS subscribe block to subscribe to some topic and the error is gone...
        However, I don't get any data on AWS IoT Core.
        I enabled CloudWatch Log for IoT Core (Settings) and set the log level to debug. I do not see my device connecting?!
          EBADF means that the client on the atom is trying to send to a closed connection.
          At one point I had to store the Public and private keys generated by amazon along with the cert on the client to get a connection.
          Try setting Keep alive to 500.
          Will need to see the full code to work out what's happening.
          AWS is constantly changing so my guides are probably out of date and need updating. I hate AWS as it a Pain.
            chr1g1
            It is still not working... Due to the fact that I'm not receiving anything on AWS, I believe it is connected to the networking on the device.
            I see a number of contradicting information and unclear guidance. Here the current approach and questions:
            1/ Internet Mode vs. App Mode. Is MQTT/IOT supposed to work in both modes?
            2/ How I'm supposed to configure networking on the new firmwares? I see the following options:
            wifiCfg.autoConnect(lcdShow=False)
            wifiCfg.reconnect()
            wifiCfg.doConnect('', '')
            wlan.connect('', '')
            3/ Playing with different firmwares because I believe this is buggy.
              Ah I see the Issue now.
              So in Internet mode the WIFI connection is already active because UIFLOW is using it to send and test programs where as in APP mode the WIFI connection is not activated because you haven't opened the connection.
              In App mode you must add the wifi configuration and setup blocks to the code for the Wireless connection to work.
              Sorry, I have been battling a chest infection and so wasn't able to clearly see the solution. While I did write the crappy book on IOT found on amazon, things have changed and I am already writing an update while working on the other deep guides.
                Your setup need to look like this:
                  chr1g1
                  Still have the problem. I rebuilt the whole program to make sure there are no "old" blocks in there. Don't even see a connection attempt on AWS (IoT Core with enabled debug logging)
                  ATOM Matrix
                  Firmware: 1.13.2
                  Both in Internet and App mode
                  -- Code --
                  from m5ui import *
                  import wifiCfg
                  import time
                  import unit
                  CO2 = None
                  TVOC = None
                  H2 = None
                  Ethanol = None
                  wifiCfg.doConnect('Guest', 'xxx')
                  wait(5)
                  aws = AWS(things_name='CO2SENSOR', host='xxx.iot.eu-central-1.amazonaws.com', port=8883, keepalive=500, cert_file_path="/flash/res/certificate.pem.crt", private_key_path="/flash/res/private.pem.key")
                  aws.start()
                  while True:
                  CO2 = tvoc_0.eCO2
                  TVOC = tvoc_0.TVOC
                  H2 = tvoc_0.H2
                  aws.publish(str('m5stack/bla'),str((py_2_json({'CO2':CO2,'TVOC':TVOC,'H2':H2,'Ethanol':Ethanol}))))
                  print('submitted to AWS')
                  wait(5)
                  — Serial Log --
                  submitted to AWS
                  [10490] MQTTException -> [Errno 9] EBADF
                  reconnect start ...
                  [14075] MQTTException -> [Errno 9] EBADF
                  reconnect start ...
                  submitted to AWS
                  [17541] MQTTException -> [Errno 9] EBADF
                  reconnect start ...
                  submitted to AWS
                  [20998] MQTTException -> [Errno 9] EBADF
                  reconnect start ...
                  [24577] MQTTException -> [Errno 9] EBADF
                  reconnect start ...
                  submitted to AWS
                    chr1g1
                    Okay - testet the very same code with an MStickC. Runs very smooth without issues. Either there are bugs in the code of the Atom Matrix or the device has just too less resources to handle an external sensor along with an IoT connection.
                      Nice work keeping at it. there is one more thing I can think of which is basically a last thing to try.
                      Add
                      import gc
                      to the import code and then at the beginning of the loop add
                      gc.collect()
                      This forces garbage collection in micropython on each pass emptying the memory on each loop.
                      Look up Micropython Garbage collection function for more information on this.
                      unfortunately I can't get into my AWS account and so haven't been able to test but it could be that you have genuinely found an issue in the Atom firmware.
                        chr1g1
                        added it as directed above. Still weird behaviour of the Atom Matrix on FW 1.13.2.
                        Here is the log:
                        I print out "submitted to aws" after the publish block in the loop.
                        APIKEY: xxx
                        submitted to aws
                        [17797] MQTTException -> 128
                        reconnect start ...
                        submitted to aws
                        submitted to aws
                        submitted to aws
                        submitted to aws
                        submitted to aws
                          chr1g1
                          okay some more learnings...
                          All S3 devices are supported by UIFlow 2.0 only. And UIFlow 2.0 is not yet supporting AWS IoT unless I missed something.
                          M5StickC Plus is working as a charm. Like M5StickC. I guess I stick with those.
                          My summary as of Feb 2024 and Firmware 1.13.2 and UIFlow 2.0 (Alpha 29):
                          Forget all new devices that are supported by UIFlow 2.0 only (e.g. *S3) and the small ATOMs if you wanna do AWS IoT stuff. Hope you find this before you bought too many devices...
                            chr1g1
                            and for completness here my working setup with M5StickC / Plus
                            Will also followup with AWS details.
                              ajb2k3 @chr1g1
                              @chr1g1 said in Atom Matrix with FW 1.13.1 not connecting to AWS:
                              Here is the log:
                              APIKEY: xxx
                              submitted to aws
                              reconnect start ...
                              submitted to aws
                              submitted to aws
                              submitted to aws
                              submitted to aws
                              submitted to aws
                              Well there is an improvement as you are no longer getting the [24577] MQTTException -> [Errno 9] EBADF
                              Which means the Atom is now working
                              Error 128 means that it tried to subscribe to the AWS topic before the connection was made.
                              If you make a subscribe and a call, according to your log it should be present.
                              add a 5 second delay after the AWS start.
