    How to connect sd card to m5stickC
    M5 Stick/StickC
    6
    13.7k
    • L
      liyouzhou
      On the product page, it says it supports an sd card interface. https://docs.m5stack.com/#/en/core/m5stickc
      But I don't see any spi pins broken out for use. So how can I add an sd card to the stick?
        ajb2k3 @liyouzhou
        @liyouzhou said in How to connect sd card to m5stickC:
        The normal esp32 can support SD Cards but the stick can’t as the dpi is in use by the display and the pins are not run out to the header( I do believe)
        • L
          lewis
          I understand the topic is quite old. But for the posterity and others who need to connect m5stckc to spi bus, yes... It is possible.
            Oh nice, Can you write up how you did it and post it on hackster please
            • F
              flypeek
              https://lang-ship.com/blog/work/m5lite-sd/
              • L
                lewis
                I got the info from this page.
                https://lang-ship.com/blog/work/m5stickc-spi-sd-3wire/
