    Cardputer display disabled after uploading sample Display code from Github
    Modules
    6.2k
    • I
      insight3fl
      I uploaded this to test product for first time and out put said "Hard reset" now display is off.
      • @file display.ino
      • @author SeanKwok (shaoxiang@m5stack.com)
      • @brief M5Cardputer Display Test
      • @version 0.1
      • @date 2023-10-09
      • @Hardwares: M5Cardputer
      • @Platform Version: Arduino M5Stack Board Manager v2.0.7
      • @Dependent Library:
      • M5GFX: https://github.com/m5stack/M5GFX
      • M5Unified: https://github.com/m5stack/M5Unified
        #include "M5Cardputer.h"
      void draw_function(LovyanGFX* gfx) {
      int x = rand() % gfx->width();
      int y = rand() % gfx->height();
      int r = (gfx->width() >> 4) + 2;
      uint16_t c = rand();
      gfx->fillRect(x - r, y - r, r * 2, r * 2, c);
      auto cfg = M5.config();
      M5Cardputer.begin(cfg);
      int textsize = M5Cardputer.Display.height() / 60;
      if (textsize == 0) {
      textsize = 1;
      M5Cardputer.Display.setTextSize(textsize);
      int x = rand() % M5Cardputer.Display.width();
      int y = rand() % M5Cardputer.Display.height();
      int r = (M5Cardputer.Display.width() >> 4) + 2;
      M5Cardputer.Display.fillCircle(x, y, r, c);
      draw_function(&M5Cardputer.Display);
      • I
        insight3fl @insight3fl
        @insight3fl I uploaded the "Buzzer test" .ino and it successfully loaded ran, and shows "Button Test" across the display. That said, none of the rest buttons seem to function so every time I turn on the device, the sketch is still running and showing the "Buzzer Test" and beeping of course.
        How do I restore the Cardputer to factory default? Pushing the go button while turning on does not seem to work.
        Thanks for helping a newbee!
        • 4
          4x0nn
          You'll need to re-upload the factory firmware. I think I saw someone uploaded it 3rd party in M5Burner. If not, I ripped a clean copy of my firmware and I'll share it tomorrow. Just click "ALL" and then search "cardputer" in the search box on the M5Burner app.
          • I
            insight3fl @4x0nn
            @4x0nn Thanks! Obviously I am a newbee and have much to learn.
            • I
              @insight3fl burner was fast and easy to retore factory default including a few extras like wifi connect. There is also one other Burner program "Nemo" that works great. I hope for us newbees there will be more packed tools. I am receiving an order today for RFID, Enviromental, motion and a few other plug in modules.
              Thank you
              • B
                blembke
                Thanks so much, I thought I bricked by cardputer and it is back.
