    M5 RS485 Modbus slave sample code does not compile
    arduino
    4.1k
    • LukeSL
      LukeS
      I have an Atom Switch that I want to use RS485 modbus with has not modbus sample code. So I trying to use sample code from the ATOM DTU devices.
      When I try to compile the sample code it gives the following error
      error: no matching function for call to 'RS485Class::RS485Class(HardwareSerial&, int, int, int, int)'
       RS485Class RS485(Serial2, ATOM_DTU_RS485_RX, ATOM_DTU_RS485_TX, -1, -1);
      Which makes sense as I don't understand where the RS485Class is defined or how it is in the below code sample. Has anyone got this working?
      #include <M5Atom.h>
      #include <ArduinoModbus.h>
      #include <ArduinoRS485.h>
      #include "ATOM_DTU_NB.h"
      const int numCoils            = 10;
      const int numDiscreteInputs   = 10;
      const int numHoldingRegisters = 10;
      const int numInputRegisters   = 10;
        Have you downloaded and installed all the libraries required in arduino?
        LukeSL 1 Reply Last reply Reply Quote 0
        • LukeSL
          LukeS @ajb2k3
          @ajb2k3 yup, all the libraries in the include section are downloaded and the compiler does not throw any missing file errors
          • R
            robertoubeperuzzo @LukeS
            I'm having the same problem testing a similar example in https://github.com/m5stack/ATOM_DTU_LoRaWAN/blob/master/examples/Modbus/ModBus-RTU/Slave/Slave.ino
            Does anyone have a working example to share?
