    SD card on M5 capsule - how to make it work ?
    Cores
    2.1k
    • L
      l31bn1tz
      I recently bought a M5 capsule, it's a super nice device. At one moment, i want to dump some files to the sd card. Unfortunately, no "sd" folder is recognized. I tried a micro sd card of 32Gb, 64Gb and 4GB. all are formatted in FAT32. But i don't see anything.
      Anyone having a similar issue ?
      Hope to solve this quick :)
      L31BN1TZ
        Have you imported and mounted the card?
        • L
          l31bn1tz
          while connecting through thonny, i can only see flash and system at the root of the device.
          What do you mean by import and mount ?
          • L
            l31bn1tz
            I solved the problem, for those having the same problem, i fix it by init the sd card :
            import os, sys, io
            import M5
            from M5 import *
            from hardware import *
            from hardware import sdcard
            def setup():
            M5.begin()
            sdcard.SDCard(slot=3, width=1, sck=14, miso=39, mosi=12, cs=11, freq=1000000)
            print(os.listdir('/sd/'))
            • L
              l31bn1tz
              specific pins are available here : https://github.com/m5stack/M5Unified
