    [Product] Grove 8x Button Unit (via STM32F0)
    Features Wish List
    5
    8
    6.6k
      Saiyande
      8 Button unit similar to "Mini Dual Button Unit" but with form factor of "8-Encoder Unit" (only with buttons).
      Add internal STM32F0 and change Grove port format to I2C.
      (also allow for reading a single byte that contains all the buttons states, one per bit, for faster reading)
      Would be useful when quickly need some buttons and don't want to use a breadboard
      1 Reply Last reply Reply Quote 6
      • K
        Kinonsc
        How about one with 50 buttons... :D
        https://shop.m5stack.com/products/cardkb-mini-keyboard-programmable-unit-v1-1-mega8a
          You can do it analogue using a resistor ladder or use an I/O expander like https://shop.m5stack.com/products/extend-i-o-unit-2-stm32f0
          alt text
          and have all 8 buttons connect to it like is a quiz show.
          Or you could make up one using the Stamp version on a breadboard:
          https://shop.m5stack.com/products/m5stamp-extend-i-o-module-stm32f0
          alt text
          Both work exactly the same.
          • O
            Otis68
            Yes, a unit with 8 backlit buttons on a matrix of 2812 LEDs.
            2 rows of 4 buttons.
            With the ability to choose any color of the button backlight.
            I2c Control Interface
              Saiyande @ajb2k3
              @kinonsc said in [Product] Grove 8x Button Unit (via STM32F0):
              Yes, lots of buttons good, but the buttons on the keyboard are tiny, not as easy to press and you have to look closely to make sure you hit the right one (unless you use one near an edge).
              @ajb2k3 said in [Product] Grove 8x Button Unit (via STM32F0):
              I built a library years ago that did analog buttons (with event firing and multiple simultaneous button press support).
              Yep, there are several ways to get multiple buttons on the M5Stack. I currently use U041-B ("I/O Hub 1 to 6 Expansion Unit (STM32F0)"): https://shop.m5stack.com/products/i-o-hub-1-to-6-expansion-unit-stm32f0
              with button boards attached as needed. It would just be nice to an inexpensive single unit to easily grab/plug.
              The nice thing about M5Stack products is you can just grab the components you need, plug them together and focus on prototyping some code. It makes it handy for quick prototyping/testing/monitoring or proof of concept, without soldering or building/moving/dismantling a breadboard.
              @otis68 said in [Product] Grove 8x Button Unit (via STM32F0):
              Good idea on adding led's like the encoder has (easer to spot the needed button based on color without having the color be a permanent button cover). 2x4 vs 1x8, I guess would come down to use/preference, 2x4 may be better though.
              O 1 Reply Last reply Reply Quote 1
              • I
                Ifantus
                More buttons would be great to have! would really hepl on the non-touchscreen products!
                • O
                  Otis68 @Saiyande
                  @Saiyande
                  Good afternoon. I am from Russia and I am writing on this forum through a translator. So I apologize for my English. The M5Stack has an I2c encoder block(U153).There are 8 of them there
                  The actual ones are 16 buttons. I don't count the encoder buttons. I would like to make a module of 4 encoders and 8 buttons (2*4) in the dimensions of the Card computer. And the backlight on the RGB LED. And with the I2c interface. You have almost ready-made software. At the price, like the encoder block, I would buy for myself. You can also make a robot control panel. Or for example with a synthesizer modeler (U178)
                  • K
                    Kinonsc
                    They have now
                    https://shop.m5stack.com/products/byte-button-unit-with-8x-buttons-stm32g031
