    M5StickC Plus 2 Official Arduino Samples Not Working (SOLVED)
    3.6k
    • B
      boredtechy
      I tried flashing the stick with M5Burner using some custom images for this device, and it works correctly. However, if I try (with the Arduino IDE 2.3.2) to upload any example from the official repository, for example: https://github.com/m5stack/M5StickCPlus2/blob/master/examples/Basic/display/display.ino, even though the code is uploaded successfully, the device does not boot. I followed the steps indicated here https://docs.m5stack.com/en/quick_start/m5stickc_plus2/arduino correctly and I have a good understanding of the Arduino IDE. I also tried recharging the stick, thinking it might be a battery issue.
      What am I doing wrong?
      Thank you
      Update:
      Hello everyone,
      I am writing just to inform you that I have resolved the issue (by contacting support) and updating to the new library M5GFX (https://github.com/m5stack/M5GFX) released a few days ago.
      I hope it is helpful to others!
      • robskiR
        robski
        does your stick loads ok with latest M5Burner firmware? Is user demo from M5Burner works? I can confirm that arduino M5stickCplus2 examples do work as had them in recently. Display, IR, Rtc, Battery, IMU, I've used Arduino 2.3.2, be sure you pick M5Stick Plus2
        • B
          boredtechy
          • B
            boredtechy @robski
            @robski said in M5StickC Plus 2 Official Arduino Samples Not Working:
            The two official images "M5stickCplus2 UserDemo V.0.1" and "UIFlow_StickC_Plus2 V.1.13.2" work correctly. I have also tried other custom images dedicated to the Plus 2, but the only one that boots correctly is Marauder.
            All sketches executed from Arduino 2 do not boot, and the screen does not turn on. I suspected some power management issue or something related to the LED, but I cannot explain why the demo is working in that case.
            I downloaded the latest M5Burner tool. What you mean with M5Burner firmware?
