    [Product Revision] TailBat with Battery Management that doesn't suck
    Features Wish List
    2.0k
    • K
      Kinonsc
      Replace the Battery Management IC with one that:
      • Has low voltage cutoff (to prevent damage to battery)
      • Has no low current cutoff (interferes with long runtime and using deep sleep)
      • Battery charge & state info (via I2C with internal switch to connect/disconnect from Grove port)
      1 Reply Last reply Reply Quote 6
      • C
        Cairnus
        The current one does suck, lol. Mainly only good as a UPS or if you need to run your thing for only a few hours since you can't sleep for longer standby use.
        • I
          Ifantus
          lots of good things in feature forum!
