[Product] RS232 in Grove Unit Format
 A TTL-RS232 level converter that connects via Grove
 (using a similar design to the Mini CAN Unit: https://shop.m5stack.com/products/mini-can-unit-tja1051t-3)
 @kinonsc said in [Product] RS232 in Grove Unit Format: https://shop.m5stack.com/products/atomic-rs232-base-w-o-atom-lite
 plus
 https://shop.m5stack.com/products/grove2dupont-conversion-cable-20cm-5pairsI could also just solder a grove connector to some cheap MAX232 boards from Ali and shrink tube them... Most of my projects deal with RS232; M5Stack makes RS485 & CAN in Grove format, it would just be nice to have RS232 in that format as well to easily plug-n-play to their MCUs.
 Did you make this yet?
 @Glintor said in [Product] RS232 in Grove Unit Format: Did you make this yet? Doesn't look like they made it yet.
 Why design it if you didn't plan to make it?
 M5Stack, any input on this? It's the only communications format not in grove format (as far as I can tell)
