    Earth sensor
    Modules
    earth sensor wrong readings
    2.4k
    • R
      rudi15
      I am a newbie to M5stack and want to use the Earth sensor to display moisture values. I followed the instructions as outlined in this video by exactly rebuilding the respective code: https://www.youtube.com/watch?v=rYi8XLe3X_c
      The device now does show data, but it is constantly above 1000 even when just laying on my desk without any contact to water (up to the maximum of 1024 which, as far as I understand, indicates that the sensor detects water (fully wet)). When I put the senor into water, the readings do not change they stay above 1000.
      Any idea what I did wrong?
      • R
        rudi15
        Update: The readings do not change even when I completely unplug the sensor. The display still gives me similar values above 1000. Thus, it somehow seems as of the sensor might not be providing any data at all? It makes no difference whether or not the sensor is attached to the device. 20240522_171840.jpg
          ajb2k3 @rudi15
          @rudi15 Can you post your UIFlow code?
          • R
            rudi15 @ajb2k3
            @ajb2k3 Sure, thanks. Here is the code:
            from m5stack import *
            from m5ui import *
            from uiflow import *
            import time
            import unit
            setScreenColor(0x222222)
            earth_0 = unit.get(unit.EARTH, unit.PORTB)
            MoistureAnalog = M5TextBox(14, 59, "Analog", lcd.FONT_Ubuntu, 0xFFFFFF, rotate=0)
            while True:
            MoistureAnalog.setText(str((str('Earth Sensor Analog: ') + str((earth_0.analogValue)))))
            wait_ms(500)
            wait_ms(2)
            • robskiR
              robski @rudi15
              @rudi15 said in Earth sensor:
              from m5ui import *
              import time
              import unit
              while True:
              wait_ms(500)
              wait_ms(2)
              Is your earth unit initialized? I cant see any reference to port B gpio
                ajb2k3 @robski
                @robski said in Earth sensor:
                from m5ui import *
                import time
                import unit
                while True:
                wait_ms(500)
                wait_ms(2)
                Judging by the colour blocks he’s using UIFlow 1 not UIFlow2
                • R
                  rudi15 @ajb2k3
                  @ajb2k3 Yes, correct UIFlow 1. Should I switch to UIFlow 2? It's indeed just that piece of code so far as I found some videos that only do that and it seems to work. No initialization or so as I could not find any information or command on initialization etc. Also, I have no idea how I would calibrate the sensor and whether that would help. In case you have any hints on what to do? Thanks again!
                  • R
                    rudi15 @rudi15
                    And just for the sake of completeness: The sensor is on Port B.
                    • robskiR
                      robski @rudi15
                      is example which you can load from Earth unit section works?
                      • R
                        rudi15 @robski
                        @robski generally yes. I can see these examples in UI Flow and I did use them when building the code.
                          ajb2k3 @rudi15
                          It wont work as the RED Port is PortA I2C, you need to connect it to a Black Port B or use a PBhub to convert to I2C
