    [Product Revision] Color Sensor (U009) - Ability to turn off LEDs
    Scheduled Pinned Locked Moved Features Wish List
    4 Posts 3 Posters 3.4k Views 2 Watching
    • Z Offline
      Zavyru
      It would be nice if there was a revision of the color sensor that allows the LEDs to be turned off/on (via I2C). So it can be used for measuring a light source's color spectrum (leds off) as well as an object's color (leds on).
      1 Reply Last reply Reply Quote 9
        holofloh
        According to the schematic the LEDs are hard connected between VCC and GND (with a 1k Resistor in serie). It may be an option to misuse the sensors INT pin and its limit threshold settings to switch the LEDs on and off. It is a open-drain with a max of 20mA. Or spend an extra I2C output driver (one Output for white LED or more if you want different LED colors - deep blue or ultra violet may be helpful to identify e.g. fluorescence).
        Anyway, it will never be a spectrometer like device as there are only 3 colored sensors with a more or less wide spectral bandwith but still gaps between.
        Z 1 Reply Last reply Reply Quote 1
        • Z Offline
          Zavyru @holofloh
          @holofloh
          Using the INT is a good idea (I was thinking an extra IC), but now that you mention it, having both white & UV could be useful to others as well.
          I shouldn't have put the word "spectrum", but rather (color) "temperature" (what I'm using the sensor for, roughly calculated from the RGB intensities). To truly read a spectral response would require a prism/grating and a linear monochromatic sensor (and calibration).
          • G Offline
            Glintor
            It would be awesome to have one with UV & White LEDs that can be turned on/off as desired.
            I made a 3D printed black cone insert that I stick in the front opening to block the light when I want to measure existing light without the LEDs interfering.
