    Error Request failed. Check the network and try again!
    UIFlow
    8
    12
    5.7k
    • Xio1996X
      Xio1996
      Everything was going great and now this afternoon I keep on getting "Error Request failed. Check the network and try again!".
      UIFLOW 2.0 can retrieve my project from the cloud but I can't save or run the program anymore.
      I opened the Web Terminal, connected via USB and ran the program, this worked. However, when I try to download the program onto my Atom Lite it goes and fetches the program from the cloud and not the edited version in the UIFLOW 2.0 editor!
      Is this just a temporary server problem or am I doing something wrong. Also, how can I download my program to the Atom Lite via USB, without UIFLOW using the cloud version?
      Many thanks for any help.
      Pete
      M 1 Reply Last reply Reply Quote 2
        mattjcuk @Xio1996
        @Xio1996 Exactly the same for me, everything was working this morning then all of a sudden getting the "Error Request" when trying to save.
        Kind regards,
        Matthew
          felmue @mattjcuk
          Hi guys
          same error here when I try to save my UIFlow2 blocks.
          @m5stack please fix.
          • A
            ankurjana
            Same issue, its definitely some cloud connection problem
            • Xio1996X
              Xio1996
              Just tried it this morning and it all works again.
              Thank you for fixing the problem.
              I was just being silly with my USB problem. It helps if I click on the USB device, doh!
                ajb2k3 @Xio1996
                @Xio1996 ROFL!
                I’ve been busy so wasn’t able to check on the server but because UIFlow uses Micropython, devices can be programmed offline using IDE’s like Thonny and Mu!
                  makingautomation
                  Hi Guys
                  I'm still having this issue and have been since yesterday.
                  Does anyone have a solution for this or is it an M5 server related issue?
                    felmue @makingautomation
                    Hi guys
                    for me it comes and goes. Sometimes it works, sometimes it fails.
                    BTW: browser console reports an 'internal server error' - so it's most likely a server side issue.
                    • R
                      rfok
                      Hello!
                      Same issue foe me
                        mattjcuk @felmue
                        It was working first thing this morning but not now.
                        Thanks,
                        Matthew
                          mattjcuk @mattjcuk
                          Seems to be back
                            SveinHa @mattjcuk
                            Started with UIFlow 2.0/M5Paper today and just when I got things to work, I got network error. Unable to transfer program using USB also... or the USB seems to work but the program transferred is an old version... Restarted my PC end lost quite a bit but still "Check network..."...
