    TF-Card
    Atom
    3.1k
    • I
      imahgin
      I own a TF-Card and wanted to create an example using UIFlow.
      As I can see in the TF-Reader schematics, header 5 contains the SPI pins, but in the AtomS3, this header is mapped to GPIO G5-G8, ADC and touch.
      In PinMap MOSI, CLK and MISO are respectively GPIO19, GPIO23 and GPIO33
      How can I configure it to use the SD card?
      BR
      • I
        imahgin @imahgin
        Acording to the product page it is compatible with Atom Matrix, Atom Lite, AtomS3, and AtomS3 Lite.
        There is available an ATOM TF-CARD Kit which includes an AtomS3 Lite, and according to its pinout, MISO, MOSI and CLK are maped to header 5, but AtomS3 don't!!!
        BR
        • I
          imahgin @imahgin
          It turns out that there are some missing information -or I didn't find it- regarding to the SPI module.
          The information available in the TF-Card page doesn't apply to the AtomS3 and there is no TF-CARD module in the Unit selection insdide UIFlow.
          I compiled and ran the example for the Arduino IDE and then tried again to build a working example using microPython.
          To whom it may interest, this is the code that works with my device:
          import os
          from machine import SDCard
          from machine import Pin
          sd = SDCard(slot=3, miso=Pin(8), mosi=Pin(6), sck=Pin(7), cs=Pin(5))
          sd.info()
          os.mount(sd, '/sd')
          print("SD card mounted at \"/sd\"")
          print(os.listdir('/sd'))
            ajb2k3 @imahgin
            @imahgin The TF adapter will be added to the BASE menu in UIFlow when the programmer get through the back log and there is no TF UNIT.
            • I
              imahgin @ajb2k3
              @ajb2k3 said in TF-Card:
              Ok, thks.
              In the meantime, I'll use this code to access to the microSD
              BR
