    M5StickC-Plus2 Battery Voltage Measuring Issue when Radio ON
    Modules
    1.5k
    • KabronK
      Kabron
      Measured values are approximatelly 0.8V greater when WiFi or BT are used.
      • KabronK
        Kabron
        Here is discharge curve with 0.8V correction.
        Correction could not be done easily by substracting the error, because below Battery voltage 3.5V, measurement begins rapidly grow. Device stops work at 3.4V.
        It is difficult to name this device as a successful design.
        • KabronK
          Kabron
          I guess, this is a possible solution for longer battery use.
          • KabronK
            Kabron
