    PM2.5 without SHT
    5 Posts 4 Posters 3.2k Views
    • G Offline
      gewe
      I got a PM2.5 module and a core. Using the m5flow / blockly there are only PM2.5 with SHT20 or SHT30 to choose - then I always get the message that SHT20 or SHT30 sensor is missing. Is there any possibility to choose PM2.5 + ENVpro sensor (wich I already have)??
      Kind regards, Gernot
      ajb2k3A F 2 Replies Last reply Reply Quote 0
        ajb2k3 @gewe
        @gewe You need to select the correct version of the PM 2.5 unit but the SHT sensors are built in to the module.
        • G Offline
          gewe @ajb2k3
          both versions do not work. I always get the error message "SHT20 Sensor maybe not connect" or "SHT30 Sensor maybe not connect"
          it seems there is no such sensor in the PM2.5
            felmue @gewe
            Hello @gewe
            the sensor SHT20 or SHT30 is in the gray base of the PM2.5 Air Quality Kit or PM2.5 Air Quality Kit(SHT30)
            From what I can tell UIFlow doesn't seem to support the PM2.5 module (w/o base).
            That said, the base seems to be available a separate item.
              frameworklabs @gewe
              Hi @gewe, what do you want to build?
              Maybe consider using Arduino as I had no troubles reading out the SHT30 on my PM2.5 with that.
              Marc
